lonesoui Posted August 13, 2011 Report Share Posted August 13, 2011 Hey guys, I did a search and tried out all of the suggestions, and I'm stuck up to this point. I was installing the ipod and bluetooth interface and I disconnected the power harness to get easier acess, but as soon as everything was plugged in and I power on. Nothing. So I did a search and people have had the same problem, so I connected the yellow battery and red ACC lines to my car battery along with the black ground wire to the ground terminal and it powers on. So I thought I might have had a loose connection, I plugged everything in and doubled checked it was connecting it they were, and still nothing. All of the fuses are still intact and I used the pins from the harness to check, so that means everything is good up until the connection. But I don't believe that my car's harness is bad right? Any other suggestions? I get so frustrated with this stupid unit. It's an Avic Z2 updated with 2010 maps and 2 wire bypassed. Thanks Quote Link to post Share on other sites
garrettoomey Posted August 13, 2011 Report Share Posted August 13, 2011 Did you check the cars fusebox for 'radio' fuse and accessory/ignition fuse? Quote Link to post Share on other sites
lonesoui Posted August 14, 2011 Author Report Share Posted August 14, 2011 I hate you garrettoomey. You make me feel like an a$$ you genius sonb!tch you. The radio fuse popped, I wouldnt have thought it at all since it was just a quick removal and reinstall. Quote Link to post Share on other sites
garrettoomey Posted August 14, 2011 Report Share Posted August 14, 2011 LOL!! Glad I could help. Quote Link to post Share on other sites
