vcyeh Posted January 22, 2007 Report Share Posted January 22, 2007 hello, I have a 2005 tsx with non-navi. I am looking to buy the avic n3 but I have few questions. I want to make the install as quick and easy as possible. So first off... 1) I understand there is a switch on the navi that will let u watch videos while in motion and also just ground the brake wire and it will be good to go. 2) What is the purpose of the VSS speed sensor wire? Is it a true necessity to have this wire in order for the avic n3 to function?? What if you do'nt connect it? if the VSS wire tells what speed you are going, doesn't normal GPS hand held units calculate your speed already?? 3) Exactly how many wires do I have to hook-up/tap-into to get the avic n3 working as intended? Power, ground, constant, brake-wire ground, two RCA cable (for my setup), and... is that mostly it??? thanks a lot! Quote Link to post Share on other sites
cntrylvr79 Posted January 22, 2007 Report Share Posted January 22, 2007 YEah so umm, Quote Link to post Share on other sites
tillithz Posted January 22, 2007 Report Share Posted January 22, 2007 a friend is only a button press away. Quote Link to post Share on other sites
bcd1 Posted January 30, 2007 Report Share Posted January 30, 2007 Like the expression goes....Read until your eyes Bleed. Good luck, bcd1 Quote Link to post Share on other sites
