rafter.shop Posted November 13, 2011 Report Share Posted November 13, 2011 When I launch the map app from the head unit, I get an error saying a GPS signal can't be found. The map then shows the entire USA, and I can't locate the car. But, when I check the radio settings, the GPS Check says it is getting a signal. Any suggestions? Thanks Quote Link to post Share on other sites
ov3n Posted November 13, 2011 Report Share Posted November 13, 2011 Do you have location services activated in your phone's settings? Quote Link to post Share on other sites
gmac78 Posted November 22, 2011 Report Share Posted November 22, 2011 Like you, i made the mistake of assuming the GPS device could totally replace the need for the iphone GPS/location services. Unfortunately this does not seem to be the case, and is more of a supplementary device.. i use something called the bad elf gps which attaches to any of the current iphones/itouch/ipads that does infact replace the need to use location services, is more accurate, and means 3g is not needed. Quote Link to post Share on other sites
simonyahn Posted April 14, 2012 Report Share Posted April 14, 2012 Did anyone find a solution to this problem. I'm having the same issue. Location services is on for maps and the gps in the radiois getting a signal Quote Link to post Share on other sites
