fifrelin Posted December 21, 2011 Report Share Posted December 21, 2011 hello, sorry for my bad english im french and i want change wallpaper on my appradio. i look the post for this but i don t understand the manipulation. please help me Quote Link to post Share on other sites
djsri Posted December 21, 2011 Report Share Posted December 21, 2011 Couple of posts down rsquared posted a great guide: Posted 21 November 2011 - 06:37 PM <p class="post entry-content " style="margin-top: 0px; margin-right: 0px; margin-bottom: 0px; margin-left: 0px; padding-top: 0px; padding-right: 0px; padding-bottom: 0px; padding-left: 0px; color: rgb(40, 40, 40); line-height: 1.6; font-family: helvetica, arial, sans-serif; ">Thanks to carver's great post, we can now change the AppRadio's main wallpaper. I originally posted my first attempt at creating custom wallpaper in caver's thread, but decided to create this new thread dedicated to custom wallpapers. I've attached 4 files. The first two are the default AppRadiowallpapers. They are in .bmp format. I used those files as templates to create my custom wallpapers. You will need to create/edit the wallpapers with some sort of photo editing software and save them as 24-bit bmp files using the exact same dimensions and filenames as the original wallpaper files (NX120_BG_1.bmp or NX120_BG_2.bmp).I used Adobe Photoshop Elements to create mine. Took me several tries to get the positioning/spacing right, but I created two wallpapers which are the 3rd an 4th attachments: First one is a Toronto Raptors background, second one is a Montreal Canadiens background. Here's how to install them: After creating your wallpapers, save them on a microSD card Download the CE66Tool.rar file: http://avic411.com/index.php?app=core&module=attach§ion=attach&attach_id=14878, extract that file and then save the CE66Tool.exe file on the same microSD card Insert microSD card in AppRadio and then turn it on - Windows will launch Double tap the My Device icon, double tap on flash card icon, select and copy your custom wallpaper files (NX120_BG_1.bmp and NX120_BG_2.bmp) Go back to My Device folder, double tap on the Nand Memory folder, double tap on CE66 folder and then double tap on Wallpaper folder Paste the custom wallpaper in the Wallpaper folder (overwrite existing files) Turn off Appradio and remove microSD card Wait at least 5 minutes and then turn on Appradio and your custom wallpaper should be there Quote Link to post Share on other sites
