Jailbreak Appradio / Appradio Plus
  • Replies 620
Posted Images
C'est vrai que mike qui est un amateur (amateur éclairé, mais amateur quand même) réussi en partie à faire dialoguer le tactile de l'iphone avec l'AppRadio.... Pourquoi Pioneer n'y arriverai pas !!!
Pioneer ne veux pas c'est sa la difference, ce sont des cons chez Pioneer... Desole de le dire comme cela, perso moi plus jamais je prendrais un autoradio de cette marque... Traite le client aussi irrespectueusement je n'ai jamais vue cela.
Hi i was wondering if any one could clearly explain what each setting does?
if u press the new appradio plus button, located behind (same button) as the original settings button.
This opens up the appradio plus screen,
scroll over to the next slide and there is a setup button press it,
now a lot of different settings can be edited.
Stuff like...
Enable hot button
Change location of menu button
Can anyone explain exactly what each setting does when turned on and off.
there is a list of 8 different settings, i understand the timezone ones (which dont seem to help anyways)
please list all settings as 1-8 and what each does.
Huge Thanks in advanced.
Stuff like...
Enable hot button
+1
Stuff like...
Enable hot button
Wait, what am I missing?
I installed AppRadio Plus and I don't see such menu options.
Just to make sure, can you guys tell me if I missed something? This is what i did:
  1. Turn on the radio, wait for home screen to be fully loaded
  2. Insert SD card with AppRadio Plus 2.50 (I already had 2.50 installed)
  3. Pushed the reboot button
  4. Windows CE loaded with the option to install AppRadio Plus, with option 1 selected tapped on OK
  5. A few files where copied and a little pop up appear on the center of the screen
  6. Tapped the little X button on that pop up window
  7. Rebooted
So what did I missed?
Thank you guys.
boujour je m'intéresse au jailbreack de mon appradio tout neuf mais je l'ai mis a jour avec la version 2.56 !!!
ma question est-il possible de le cracké grace a la derniere version proposé sur ce topic ou dois-je attendre une autre version
merci a vous !!!
merci a vous !!!
Pour le moment la derniere version fonctionne avec la 2.50, si tu veux installer appradio plus, tu dois downgrader
Hi to all, i 'm not sure but seems that new firmware have an improved radio fm reception ...
so the same question again and again ?
can the appradio work with appradio extension on 2.56 firmware ?
is there a new version on the "road" ?
