silver9195 Posted August 7, 2012 Report Share Posted August 7, 2012 ok je refait tout et je te dis, merci encore pour ton boulot ! Quote Link to post Share on other sites
thaywood2386 Posted August 7, 2012 Report Share Posted August 7, 2012 is there anyway to hack the bluetooth driver to enable A2DP so you can stream music over bluetooth? Quote Link to post Share on other sites
silver9195 Posted August 7, 2012 Report Share Posted August 7, 2012 parfait Dejan cela fonctionne ! merci Quote Link to post Share on other sites
Dejan Posted August 7, 2012 Author Report Share Posted August 7, 2012 is there anyway to hack the bluetooth driver to enable A2DP so you can stream music over bluetooth? Its better release a hack for have sound driver in SD card... For directly have mp3 in sd card and have sound in igo... But at time no solution Quote Link to post Share on other sites
Dejan Posted August 7, 2012 Author Report Share Posted August 7, 2012 parfait Dejan cela fonctionne ! merci De rien je mettrai apres les vacances a dispo ma derniere version, sinon j'ai contacter igo pour igo 9, il refuse de vendre a l'unite pour un particulier (1000 commande de licence minimum) et lorsque j'ai demande comme passe de igo8 a igo9 il mon repondu a peu pres la meme chose : Dear Dejan, First of all, thank you for your interest in our products! Unfortunately, iGO navigation is only available pre-installed by the device manufacturer. It is not available in shops. If you have further questions, do not hesitate to contact us! Best regards, NNG Support Quote Link to post Share on other sites
silver9195 Posted August 8, 2012 Report Share Posted August 8, 2012 ok supper je suppose que la nouvelle version de igo 8 que tu as amélioré résou le soucis de l'heure ? et pour la voix on l'aura jamais ? merci encore Quote Link to post Share on other sites
Dejan Posted August 8, 2012 Author Report Share Posted August 8, 2012 Moi je n'ai plus de soucis avec l'heure, en faite il faut regler ton appradio plus (dans option sur GMT) Ds ma nouvelle version j'ai des skins et le panorama 3D fonctionne, j'ai egalement mis a jour qq fichier et bug fix Pour la voie le pb ne vien pas d'igo mais de l'appradio... Quote Link to post Share on other sites
silver9195 Posted August 8, 2012 Report Share Posted August 8, 2012 ok je dois régler le GMT ou ? sur winCE ? tu l'a mis en ligne ta nouvelle version d'IGO ? Quote Link to post Share on other sites
Dejan Posted August 8, 2012 Author Report Share Posted August 8, 2012 Dans appradio plus, tu va sur l'icone reglage et c la dedans, non g pas mis en ligne la pas le temps desole je par demain pour les balkans a mon retour Quote Link to post Share on other sites
silver9195 Posted August 9, 2012 Report Share Posted August 9, 2012 ok j'ai réussi pour l'heure merci ! passe de bonne vac Quote Link to post Share on other sites
Dejan Posted August 9, 2012 Author Report Share Posted August 9, 2012 ok j'ai réussi pour l'heure merci ! passe de bonne vac Merci j'up a la rentre la derniere sans pb Quote Link to post Share on other sites
late Posted August 9, 2012 Report Share Posted August 9, 2012 posted in the thread about the warning message but will post here as well to get more help. about skipping the first OK screen i cant seem to get it to work? i installed it and went to setup, saw the message about wait time for ok message and assumed that was it but could not get it to work. tried 0, 1, and the default 1000 and didnt work at all, latest 2.63 version Quote Link to post Share on other sites
Dejan Posted August 9, 2012 Author Report Share Posted August 9, 2012 No settings need... Just install last firmwar 2.63, reboot and install appradio plus 2.63 and reboot, the first start you choose language and press ok for warning message, after turn off your car 5 min and start appradio no need again to press ok... Only for appradio 1 Quote Link to post Share on other sites
late Posted August 9, 2012 Report Share Posted August 9, 2012 No settings need... Just install last firmwar 2.63, reboot and install appradio plus 2.63 and reboot, the first start you choose language and press ok for warning message, after turn off your car 5 min and start appradio no need again to press ok... Only for appradio 1 i do have the appradio 1, sph-da01, i installed it and it didnt do it for me. guess ill try to reinstall and see if that works. reinstalled and its all good! thanks Quote Link to post Share on other sites
Dejan Posted August 10, 2012 Author Report Share Posted August 10, 2012 i do have the appradio 1, sph-da01, i installed it and it didnt do it for me. guess ill try to reinstall and see if that works. reinstalled and its all good! thanks Super !!!! Now enjoy your appradio its now a other product Quote Link to post Share on other sites
