fighterzg6 Posted October 17, 2012 Report Share Posted October 17, 2012 Hello, it would be possible to turn off the timer for five minutes to change radios in a quarter of an hour or more? MfG fighterzg6 Quote Link to post Share on other sites
olsen185 Posted October 18, 2012 Report Share Posted October 18, 2012 throughout this thread several people have asked for the proper uninstall procedure, but I haven't found the answer. Could someone explain the process to me? Quote Link to post Share on other sites
yonel Posted October 20, 2012 Report Share Posted October 20, 2012 simply go to setup through icons on appradio "plus" fonctions... Quote Link to post Share on other sites
Alex.Cannes Posted November 25, 2012 Report Share Posted November 25, 2012 Bonjour a tous, je viens de commander l'autoradio pioneer SPH DA02, est j'aurais aimé savoir si celui ci est bien compatible avec tous vos jailbreak pour le SPH DA01. Et si ne n'est pas le cas, m'indiquer alors s'il y a des jailbreak compatible pour cellui ci. Je devrais reçevoir mon autoradio d'ici une semaine, si tous va bien et que le site respecte ses engagements ... Merci d'avance pour vos réponses éventuelle. Quote Link to post Share on other sites
close Posted November 25, 2012 Report Share Posted November 25, 2012 Bonjour, J'ai un Appradio SPH-DA02 avec le firmware 4.14 Est ce que je peut le jailbreacker. Je n'ai pas trouvée de réponse sur ce modèle avec le soft 4.14 Merci de vos réponse. Cordialement. Quote Link to post Share on other sites
close Posted November 25, 2012 Report Share Posted November 25, 2012 Hello, I have a SPH-DA02 AppRadio with firmware 4.14 Is what I can jailbreacker. I have not found an answer on this model with soft 4.14 Thank you for your reply. Cordially. Quote Link to post Share on other sites
yonel Posted November 25, 2012 Report Share Posted November 25, 2012 pour le sph-da02.... je ne sais pas du tout...contrairement au da01 dispose de sa micro sd en facade et qui permet de charger le mode appradio plus.... en theorie ce n'est pas impossible ( suffirait de se mettre comme en mode mise à jour avec le programme appradio plus ) mais en pratique....c'est un risque potentiel pour vos postes...( je ne me souviens plus du contenu des 33 posts de ce sujet ...) Quote Link to post Share on other sites
yonel Posted November 25, 2012 Report Share Posted November 25, 2012 bon selon Dejan, et je lui fais entierement confiance à ce sujet, appradio 2...negatif ( sauf si quelqu'un veut "risquer" ) Quote Link to post Share on other sites
close Posted November 25, 2012 Report Share Posted November 25, 2012 Salut, Merci de ta réponse rapide, Sur le SPH-DA02 il a la même configuration physique lecteur de carte SD en façade mais aucune idée de la différence entre les deux modèle peut être l’électronique. Je ne vais pas tenter le risque et suivre vos conseil. Qui sait peut être avec le temps les Russe trouverons peut être une solution. Sinon il n'y aurai pas une astuce pour supprimer le message d'avertissement au démarrage, c'est ce qui me gêne le plus. Merci bonne soirée Quote Link to post Share on other sites
Alex.Cannes Posted November 26, 2012 Report Share Posted November 26, 2012 merci de ta reponse yonel Quote Link to post Share on other sites
POPS Posted November 27, 2012 Report Share Posted November 27, 2012 Salut, Moi aussi j'ai un SPH DA02 et j'ai essayé de le jailbreaké comme le DA01 avec le firmware 4.14 mais ca a pas marché J'ai donc essayé comme pour le DA100, mais là , non plus. J'ai essayé tous ce qui est possible, mais rien a faire! Elle est plus tetu que moi cette bête là !! Je l'ai donc mis a jour en 4.16, tout recommencé mes essaie de jailbreak et toujour rien!!!!! J'espere maintenant, qu'on va pas nous laisser sur le bord de la route avec notre DA02… Quote Link to post Share on other sites
Dejan Posted November 27, 2012 Author Report Share Posted November 27, 2012 Bonsoir, Seul le 1er model est compatible avec le jailbreak les autres ne le sont pas. Pour retirer le message d'alerte seul appradio plus peu le faire grace a un auto click... Je ne pense pas qu'un jailbreak arrivera sur les autres gammes ios sachant que ce poste est une veritable deception... Quote Link to post Share on other sites
ben17 Posted December 8, 2012 Report Share Posted December 8, 2012 Bonjour je possede l'appradio depuis sa sortie mais je vais abandonné l'iphone pour un android.Je voudrais donc savoir s'il y avait une solution (jailbreake ou non) pour utiliser un smartphone android sur mon SPH DA01 ? Si ce n'est pas possible je suis pret a echanger mon SPH DA01 (qui permet les jaiblreak) contre un SPH DA100... Quote Link to post Share on other sites
Dejan Posted December 8, 2012 Author Report Share Posted December 8, 2012 Salut, tu peux changer.... le 1er model n'est pas compatible android et aucune solution pour. perso je te conseil d'abandonner l'appradio même avec la version android tu sera dans le "caca" pour etre polie. L'appradio Android ne supporte pas Jelly Bean "lol" un comble... donc galaxy S3 et cie... ne fonctionnerons pas avec Pioneer une marque à bannir lorsque l'on souhaite une interactivité avec un autre appareil ! Quote Link to post Share on other sites
yonel Posted December 9, 2012 Report Share Posted December 9, 2012 Dejan.... et ça ? Quote Link to post Share on other sites
Join the conversation
