appify Posted January 15, 2013 Report Share Posted January 15, 2013 Hello, take off you microsd card and reboot... For navigation only igo 8 mips run in appradio whitout iphone... With iphone igo primo and navgate drive. Navfree, waze. I tried that as well, but then it says iGo cannot be found. Therefore I thought the SD card should stay in the radio. To summarize what I did 1. Copy the appradio plus files on an SD card and put it in the radio 2. Install AppRadio plus. When the installation is complete, turn off radio and remove SD card. 3. Boot radio, click on Igo 4. "iGo cannot be found". Quote Link to post Share on other sites
Dejan Posted January 15, 2013 Author Report Share Posted January 15, 2013 Have you install igo in your sd card ? Quote Link to post Share on other sites
Dejan Posted February 17, 2013 Author Report Share Posted February 17, 2013 Yes no probleme work with and without its compatible but no necessary Only for sph -da01 Quote Link to post Share on other sites
bakiraga Posted February 21, 2013 Report Share Posted February 21, 2013 Dont install 2.46 / this version i a test of me 2.46 = 2.22 Install directly release of Sserhy working great !!!! For navigation use igo is the must actualy for appradio display (djskam have post one release in this topic) i upload my igo asap Dejane ba de mi na nasem objasni kako da app radio krekenujem preko mini sd kartice imam ovaj radio model sph02 ,u kaeticu sam ubacio ovaj softwer app radio plus ali nikako neide sta da uradim breee...... Quote Link to post Share on other sites
Dejan Posted February 21, 2013 Author Report Share Posted February 21, 2013 Dejane ba de mi na nasem objasni kako da app radio krekenujem preko mini sd kartice imam ovaj radio model sph02 ,u kaeticu sam ubacio ovaj softwer app radio plus ali nikako neide sta da uradim breee...... Ne radi za sph02 samo za sph01 Quote Link to post Share on other sites
bakiraga Posted March 8, 2013 Report Share Posted March 8, 2013 Ne radi za sph02 samo za sph01 Ok Dejo Steta Danke Digger..... Quote Link to post Share on other sites
Dejan Posted March 8, 2013 Author Report Share Posted March 8, 2013 nema na cemu Quote Link to post Share on other sites
zetaR Posted March 14, 2013 Report Share Posted March 14, 2013 there exists the possibility of an output of the firmware jailbreak for DA100? Quote Link to post Share on other sites
ElayZ Posted April 15, 2013 Report Share Posted April 15, 2013 Hi, i made a Dutch translation. Just got my Appradio DA01(for cheap!) and i'm figuring out what i can do with it. I'm going to install the AppradioPlus firmware tomorrow. Thnx for all the work you guys put into this. [edit] installed, nothing seems different, i can't open the additional menu. When i go to settings, nothing but the original settings... If there's still anyone out there reading this old topic, help?! What i did: - upgraded AppRadio to 2.63 official firmware. 60% in upgrading eboot i got an error msg saying: Application CIS.exe has performed an illegal operation and will be shut down. If the problem persists, contact the program vendor. Program: CIS.exe Exeption: 0xC0000005 Adress: 01CE656C Appradio froze, so all i could do is hit the reboot button. Tried eboot upgrade again, it said completed. So i installed the second part of the upgrade with SD card 2. No problems at all. If i check fw version now it says 2.63 and all seems to be working fine. So i installed the latest AppradioPlus files i could find in this topic: SD_AppRadio_plus_26_263 Install went without any errors. Only i can't seem to get the additional menu. I tried putting the Drive_Win_CE_Mips.rar files on the SD card, but that doesn't do anything... language.rar Quote Link to post Share on other sites
jb92578 Posted April 19, 2013 Report Share Posted April 19, 2013 Is this for app radio only? Or will it work on other pioneer units in app radio mode? I have an avh-x8500bhs.. I don't want to damage it if this isn't compatible by trying to install.. Thanks Quote Link to post Share on other sites
bakiraga Posted April 24, 2013 Report Share Posted April 24, 2013 Ne radi za sph02 samo za sph01 Ne radi za sph02 samo za sph01 Nagodio sam ba Dejo radi kao svajcarski Sahat ubacio sam software od sph01 u moj sph02 app radio i poslije toga instalirao appRadio plus i radi pravo sada rastura.....Hajde Pozdrav iz Hamburga..... Quote Link to post Share on other sites
Dejan Posted April 25, 2013 Author Report Share Posted April 25, 2013 Nagodio sam ba Dejo radi kao svajcarski Sahat ubacio sam software od sph01 u moj sph02 app radio i poslije toga instalirao appRadio plus i radi pravo sada rastura.....Hajde Pozdrav iz Hamburga..... Jel radi ??? Znaci nema vise warning message ??? Quote Link to post Share on other sites
ElayZ Posted April 26, 2013 Report Share Posted April 26, 2013 Can some of you smart french guys please make a how-to guide on installing this? (maybe in the topic start?) With the right links etc? Because alot of non-french folks here don't seem to get it... (including moi! ) I'm stuck. I installed Apradio+ software (it sayd installation succesfull) but i don't get the additional menu. Everything is still the same as before... Is there btw any method to speed up the appradio because its slooooow takes ages when it's booting up before you actually see the menu and everything. Quote Link to post Share on other sites
WRS Posted April 27, 2013 Report Share Posted April 27, 2013 Can some of you smart french guys please make a how-to guide on installing this? (maybe in the topic start?) With the right links etc? Because alot of non-french folks here don't seem to get it... (including moi! ) I'm stuck. I installed Apradio+ software (it sayd installation succesfull) but i don't get the additional menu. Everything is still the same as before... Is there btw any method to speed up the appradio because its slooooow takes ages when it's booting up before you actually see the menu and everything. go into the settings menu of the iphone and scroll down to appradioplus and open it? In there is where you will find the setting for what will show up on the radio. Also a major complaint of the Appradio is its slow boot time. No fix that I know of. Quote Link to post Share on other sites
ElayZ Posted May 8, 2013 Report Share Posted May 8, 2013 go into the settings menu of the iphone and scroll down to appradioplus and open it? In there is where you will find the setting for what will show up on the radio. Also a major complaint of the Appradio is its slow boot time. No fix that I know of. Eehm.. settings menu on the iPhone?? I don't have a appradioplus app on my iphone, and there is none @ the store... (or do you need to have a JB for this?) i saw youtube vids wich showed an extra menu on the appradio with wich you can run iGo navi from an SD card without the iPhone... Quote Link to post Share on other sites
Join the conversation
