2Kings920 Posted April 27, 2012 Report Share Posted April 27, 2012 So I just installed the iSimple is76 and now I can watch videos on my Z1. But now I've lost my GPS mapping, all it shows now on my map is the red arrow on a blue screen and **:** for the time, oh and the MPH is way off too. In park it shows 0mph but as soon as I put it in gear with the brake held, it slowly increases mph and I'm not moving. Any ideas??? Quote Link to post Share on other sites
garrettoomey Posted April 27, 2012 Report Share Posted April 27, 2012 None of the symptoms that you describe can be caused by connecting an AV cable. I assume you had to remove the unit to access the AV connectors on the back. It sounds like like you no longer have GPS antenna signal. Check signal strength in the menu options and report back. Maybe you did not reconnect the GPS antenna? Quote Link to post Share on other sites
2Kings920 Posted April 28, 2012 Report Share Posted April 28, 2012 I checked signal strength and it shows OK with a green antenna but the bars to the right of that are grey, should they be lit up green to show strength? Quote Link to post Share on other sites
garrettoomey Posted April 30, 2012 Report Share Posted April 30, 2012 I think they light up orange. You should have at least 4 or 5 lit up. Quote Link to post Share on other sites
