crazed_z06 Posted June 23, 2012 Report Share Posted June 23, 2012 I just registered here because I installed a x940 last night and can confirm the videos are correct. On my harness, I just had to move the yellow wire up one notch. Quote Link to post Share on other sites
coolguy2010 Posted July 6, 2012 Report Share Posted July 6, 2012 I just registered here because I installed a x940 last night and can confirm the videos are correct. On my harness, I just had to move the yellow wire up one notch. I am going to get 940 installed tomorrow. can you please also clarify if you also had to ground the other wires as mentioned in some videos OR just had to move the yellow wire up one? Thanks! Quote Link to post Share on other sites
coolguy2010 Posted July 8, 2012 Report Share Posted July 8, 2012 I got the 940BT installed yesterday but the bypass is not working. The bypass was done using the steps in Video 1..it cuts off video after 40-45 speed with an attention message. anyone else had this issue after the bypass and suggestions to fix it? Quote Link to post Share on other sites
soze Posted October 18, 2012 Report Share Posted October 18, 2012 I got the bypass working for the 940bt the first time... using this... http://www.ebay.com/...984.m1436.l2649 I went ahead and bought an extra wire, because I didn't want to remove the mute wire and re-use it. I wanted to keep the wire where it was, and just add an additional one. This kit was all hooked up with the proper connector and ready to go. Basically plug and play. On the other end of the wire... I joined the Parking brake wire (green) + this bypass wire + pioneer ground (black) + harness ground (black) together. Quote Link to post Share on other sites
dannymk2 Posted October 26, 2012 Report Share Posted October 26, 2012 does moving the mute wire pose an issue for the bluetooth on the radio? Quote Link to post Share on other sites
VBLUE42 Posted October 28, 2012 Report Share Posted October 28, 2012 No. Quote Link to post Share on other sites
werewolf Posted December 26, 2012 Report Share Posted December 26, 2012 I hate to bring up an old thread but thought it be better than starting a new one on this topic. With the bypass can I grab any extra wire and use it bc I have to use the mute wire for my truck. Thanks Quote Link to post Share on other sites
Bbeelzebub Posted December 27, 2012 Report Share Posted December 27, 2012 I hate to bring up an old thread but thought it be better than starting a new one on this topic. With the bypass can I grab any extra wire and use it bc I have to use the mute wire for my truck. Thanks I believe using the hack posted on this forum, you lose Mute. However, I know I had a pro install done and they used a microbypass and I still have mute. If you search on youtube, there is a video for the other method using a microbypass, which I believe you can do yourself. Quote Link to post Share on other sites
