X940BT - Pandora and bluetooth not working?
Well Bluetooth is wireless. And nowhere in the documentation does it say anything about being able to operate the Pandora source or Aha over Bluetooth. You can of course use the Bluetooth streaming source with Pandora but you wont get the same interface as with the Pandora source.
  • 3 weeks later...
so... if you hook it up like it says in the manual, it works fine, but when you try to connect in a way that is not shown in the manual it doesn't work? sound about right?
sounds like you already have your answer.
  • 3 months later...
welcome to the wonderful world of bluetooth, sometimes it works great, sometime it doesn't work at all, most of the time its somewhere in between.
the only things you can do are check to see if there is a BT update for either the phone or the AVIC, then delete the pairing and re-pair the devices.
