Willpal69 Posted March 1, 2021 Report Share Posted March 1, 2021 Hi there, if anybody is still tracking this thread would it be possible to send me the files for the UK? I recently got my car back from the Ex and the F900bt is stuck in the startup loop. I have no idea where to start with the issue. Any help would be greatly appreciated. Thanks. Will. will.palmer.69@googlemail.com Quote Link to post Share on other sites
Juliano Posted June 30, 2021 Report Share Posted June 30, 2021 Alguém tem arquivo de imagem do avic f80tv? Quote Link to post Share on other sites
Juliano Posted June 30, 2021 Report Share Posted June 30, 2021 On 5/31/2012 at 10:27 PM, tail24 said: This is from a post I just did for another member I feel like I kind of give the short un orgainzed version to lots of people but here is a more organized version. This is not a fix all but it will often fix many reboot problems, some are more complicated which may not allow you in to test mode, or may even reboot after files have been replaced. This should be attempted before the Pinned MBR fix is tried. go to this thread ; http://avic411.com/i...f-avic-f-files/ Its also pinned to the top here "Torrent Full of Avic F files" download the zip with a torrent file with in it. Use a torrent downloader (Azerus Vuze, Utorrent, Bittorrent, ect) to download the larger torrent to your computer (its 8.4 gb and should take much of the rest of the evening to download). Once these files have been downloaded 1. Format an SD card that is at least 2 gb big. 2. Unzip the file you have downloaded 3. Locate the File Testmode V 2.3. Open folder Copy the folder within entitled "testmode" 4. Paste that file into the root level of your SD card 5. Locate folder "My Flashdisk Back up" Open it then Open the folder 2.0 f700 Copy this folder 6. Paste that file/folder into Root level of your SD card along with "test mode" 7. Eject SD card and head to car 8. Put SD card in avic and turn it on 9. wait for avic to load into test mode (likes like windows 95 its called WindowsCE) 10. Click Start > Programs> Windows Explorer 11. Double Click SD card > Double Click f700 up top click edit>select all then Edit>Copy 12. Click Start > Programs > Windows Explorer (again) to open a second finder window 13. Double Click "My Flash Disk" that looks like a grey little icon 14. you will see a bunch of folders and icons it should look similar to when you opened F700 folder from SD card Click uptop Edit Paste 15. If you are given an error message about not enough room ignore or x it out ( i forget the exact step) 16. If asked if you want to replace file, select YES ALL 17. You will see that its gonna take upto 2 hrs but in reality it takes about 15 minutes to replace all files. 18. Once its finished turn off our car 19. eject SD card 20. Turn on Car hopefully at this point it loads perfectly like its a new avic... this may take a few momments and in initial menu it will say please wait system start up in process. 21. If its stuck in loop mode put SD card back in and re enter test mode go back to "My Flash Disk" delete all the files that say "gpspara(number).bin If this doesnt work you need further help which is doable in most cases but its more indepth. This at least will give you a basic understanding of how to navigate inside WinCe Glad to see/hear that this thread is helping lots of people, I hope it continues to do so. Also several people have asked for my paypal account for helping them out my email for paypal or further help if you are really stuck and for some reason i dont respond here quick enough (with in 3 days... please give me 3 days to respond) is tail24@aol.com make subject Avic Help. Thanks to all that have donated and do in the future, but dont worry I will help without any donation what so ever some just feel like giving because they are saved lots of money. Link torrent não existe mais! Quote Link to post Share on other sites
Conzoli Posted June 14, 2022 Report Share Posted June 14, 2022 Hello, can you send me a link to torrent: "Torrent Full of Avic F files" files please? I have a problem with my AVIC F980BT device which started to reboot on its own while running. conzolite@gmail.com Thank you! Quote Link to post Share on other sites
Magician6630 Posted October 2, 2022 Report Share Posted October 2, 2022 Hello I see this is a old treat but possible open for download again Torrent Full of Avic F files? I have a AVIC F980DAB is stuck in boot, was a falure FW load from prev owner. THX Quote Link to post Share on other sites
WolchaDaniel Posted May 9 Report Share Posted May 9 Hi all, my f900bt (for Europe) worked very well for the last 10 years. 2 weeks ago it started with rebooting loop, too. May I also ask to the experts, to please provide all the files needed to fix this issue. All links provided in this treat unfortunately do not work anymore or I do not have access to them. Thanks a lot in advance. BR Daniel Quote Link to post Share on other sites
Join the conversation
