dutt88 Posted March 8, 2016 Report Share Posted March 8, 2016 not sure if I'm trying to do the right thing or not my avic f700bt keeps rebooting it works fine for about 3 minutes then shuts down and starts rebooting again... I'm looking up information on how to update the system but I'm not sure if its gonna work if you guy think it will work please post links to the updates Ive called pioneer but they want 230 dollars to fix it... really hoping I can get the help I'm looking for on here be I don't want to spend that kind of money..... tia.... Quote Link to post Share on other sites
guizmo Posted March 10, 2016 Report Share Posted March 10, 2016 https://drive.google.com/file/d/0B4MAukIOceEXZFN3WjlLbzVlOUk/view?usp=sharing Quote Link to post Share on other sites
t30485 Posted April 7, 2016 Report Share Posted April 7, 2016 not sure if I'm trying to do the right thing or not my avic f700bt keeps rebooting it works fine for about 3 minutes then shuts down and starts rebooting again... I'm looking up information on how to update the system but I'm not sure if its gonna work if you guy think it will work please post links to the updates Ive called pioneer but they want 230 dollars to fix it... really hoping I can get the help I'm looking for on here be I don't want to spend that kind of money..... tia.... Isn't the shut down and rebooting after a period of time usually a sign that the cooler fan is dead or not working properly? Quote Link to post Share on other sites
silveirce Posted April 12, 2016 Report Share Posted April 12, 2016 Hello, tried to make an upgrade on an Avic F900 BT. Got the bluescreen and tried option 0. But then I get the message 100% immediately and when I restart I still got the old firmware on it. Any suggestions? What is that "license" folder for? Thanks, Mike from Germany Quote Link to post Share on other sites
akbarirfan Posted April 27, 2016 Report Share Posted April 27, 2016 Thanks need to try this. Quote Link to post Share on other sites
akbarirfan Posted May 2, 2016 Report Share Posted May 2, 2016 I got stuck at Reading 100%, I then used a Smaller memory card (1gb) and the wince upgrade worked. Quote Link to post Share on other sites
algutiss Posted July 9, 2017 Report Share Posted July 9, 2017 Hi All, When I try to open the guide from google I get the message error topic does not exist.. Is there a reason for this? I've found what I think is the correct software if this helps anyone.. Can someone help me with the correct method? Thanks! http://www.mediafire.com/?fk177j7sk65d5pd http://www.mediafire.com/?j4agh9jemp2ml0c http://www.mediafire.com/?dhsy1fe8m50vaks Hi, Can you check these files, because in the second and third link zip files is damaged. If it's possible can you renew it? Thank you very much. Quote Link to post Share on other sites
alnath Posted July 14, 2017 Report Share Posted July 14, 2017 Hello, Can I use this Hybrid on a F960BT with installed version 1.14 and what could be done for a prior back-up? I've seen that Testmode only works from 3.0 and up. I already have the latest 2017 maps for EU, but I like to try a newer and smoother version too Thanks guys! Quote Link to post Share on other sites
djl75 Posted November 3, 2018 Report Share Posted November 3, 2018 On 2016-05-02 at 6:04 AM, akbarirfan said: I got stuck at Reading 100%, I then used a Smaller memory card (1gb) and the wince upgrade worked. any resolution to this problem. I am having the same issue Quote Link to post Share on other sites
guisser Posted December 15, 2019 Report Share Posted December 15, 2019 On 26/05/2015 at 14:03, dws said: téléchargé toutes les cartes de ce post et tout fonctionne bien! merci beaucoup merci le fichier n'existe pas Quote Link to post Share on other sites
