DMB#41 Posted February 14, 2007 Report Share Posted February 14, 2007 Hey guys, I am installing my AVIC right now and cant seem to figure out which wire is the VSS. My old stereo had the gets quiet or loud depending on speed, so it must be in one of the 3 harnesses I found. I am also looking for my reverse wire. Thanks, Matt Quote Link to post Share on other sites
cntrylvr79 Posted February 14, 2007 Report Share Posted February 14, 2007 Ok so which vehicle do you need vss for? If it's the hivstic, it's blue at the radio harness. The crv is below Speed Sense white/green or blue/white ECM/PCM, pin A18 or E26 Notes: The ECM/PCM is behind the glovebox. Connector A is a gray 31 pin plug. Connector E is a white 31 pin plug. Reverse for the hivstic Reverse Light brown (4dr) or purple (2dr) + dr kick or fuse box, top 42 pin plug Crv Reverse Light green/black + frt of fuse box, 18 pin plug, pin 1 merry xmas. Quote Link to post Share on other sites
DMB#41 Posted February 14, 2007 Author Report Share Posted February 14, 2007 thanks man!! I need all the help I can get. Its a 2007 CR-V, i figured they would be the same. I am trying to locate those wires now Quote Link to post Share on other sites
DMB#41 Posted February 14, 2007 Author Report Share Posted February 14, 2007 cntrylvr79, There are no wires behind my glove box... There was 3 harness behind the dash plugged into the stock unit and 2 of the 3 harnesses has a blue wire. Is that info for the 2007 CR-V?? thanks again for all your help Quote Link to post Share on other sites
cntrylvr79 Posted February 14, 2007 Report Share Posted February 14, 2007 That's what I have listed for an 07 civic and an 07 crv. If there's 2 blue wire and the factory radio had speed controlled volume test them. One of them might be vss. Quote Link to post Share on other sites
DMB#41 Posted February 14, 2007 Author Report Share Posted February 14, 2007 Thanks again !! ill try it out Quote Link to post Share on other sites
DMB#41 Posted February 23, 2007 Author Report Share Posted February 23, 2007 I have looked and looked but still can't find my VSS wire. I think its causing my navigation to be slightly off sometimes when I take an exit or turn. I have tried suggestions given before and still no VSS. Does anyone know were I can find it?? thanks again, Matt Quote Link to post Share on other sites
DMB#41 Posted February 27, 2007 Author Report Share Posted February 27, 2007 After some serious trial and error I found it!!! If anyone else is looking for VSS in the 2007 Honda CR-V it is the dark blue in the middle of the main harness (i.e. the harness with power ground and all the speakers.) Quote Link to post Share on other sites
