punit12 Posted August 19, 2013 Report Share Posted August 19, 2013 Hi there, new to the forum. I recently bought my DA100, got it professionally installed, and came home and installed the 8.30 firmware updates. I then paired my iPhone 5 via bluetooth (can make calls via the headunit, it sees my contacts etc), and then plugged the phone in via the lightning to av adapter. The phone bleeps and starts charging, and briefly a bright blue bar appears across the top of the phone. But, after a week and a half of trying, the "Apps" icon on my headunit is still greyed out! I've restored my phone (lost jailbreak in the process!), reset the headunit, updated the firmware again, deleted my phone from the headunit, but nothing I do can "un-grey" the "apps" icon on the DA100! This is so frustrating, is there anyone who can help me? Also, the connection setting reads "iPhone-Digital AV". One more thing, if the HDMI cable is loose from the back, would this grey out the icon? What else can cause this? Do I have a faulty head unit? Thanks for any help! Quote Link to post Share on other sites
texbuck Posted August 19, 2013 Report Share Posted August 19, 2013 Do you have a parking brake bypass installed? Quote Link to post Share on other sites
punit12 Posted August 19, 2013 Author Report Share Posted August 19, 2013 Do you have a parking brake bypass installed? I don't think so, I'm in the UK so I don't think the unit even comes with anything to connect to the parking brake/handbrake? Quote Link to post Share on other sites
sandman77 Posted August 19, 2013 Report Share Posted August 19, 2013 Go into the settings of the head unit and make sure the setting for phone connection is set to digital and not other. Quote Link to post Share on other sites
punit12 Posted August 19, 2013 Author Report Share Posted August 19, 2013 Go into the settings of the head unit and make sure the setting for phone connection is set to digital and not other. Yep it's always been set to digital AV, still no change Quote Link to post Share on other sites
sandman77 Posted August 19, 2013 Report Share Posted August 19, 2013 When you upgraded the firmware did you install both files (one at a time)? Quote Link to post Share on other sites
punit12 Posted August 19, 2013 Author Report Share Posted August 19, 2013 When you upgraded the firmware did you install both files (one at a time)? Yes I did, I've done the update (both files) twice now! Quote Link to post Share on other sites
VBLUE42 Posted August 20, 2013 Report Share Posted August 20, 2013 Make sure your parking brake wire is grounded to achieve the bypass. And yes, certainly make sure the HDMI cable is fully plugged in. Quote Link to post Share on other sites
