Animal34 Posted June 16, 2014 Report Share Posted June 16, 2014 So recently had my 7000 installed problem is I have no navigation just returns to the normal screen my aha and pandora are grayed out and so is my vehicle information not sure what to do faulty unit or issue with install seems like only the radio sd cd player work should I try to reset it . New here so any help would be great also how do I do the reset on this thing Quote Link to post Share on other sites
drenyce311 Posted June 16, 2014 Report Share Posted June 16, 2014 are you connected via USB?? What happens when you press the MAP button?? Quote Link to post Share on other sites
Animal34 Posted June 16, 2014 Author Report Share Posted June 16, 2014 Will bring me to the warning screen then I click ok it flashes like its going to load then brings me back to home screen. And so far I got pandora and aha working via Bluetooth Quote Link to post Share on other sites
tekki Posted June 16, 2014 Report Share Posted June 16, 2014 So recently had my 7000 installed problem is I have no navigation just returns to the normal screen my aha and pandora are grayed out and so is my vehicle information not sure what to do faulty unit or issue with install seems like only the radio sd cd player work should I try to reset it . New here so any help would be great also how do I do the reset on this thing I think another member on the forum had a similar problem, I believe his unit wasn't grounded properly, or his gps antenna wasn't in properly. You should probably check that and report back. Quote Link to post Share on other sites
