Camry8000nex Posted August 16, 2014 Author Report Share Posted August 16, 2014 The camera was OEM, they tried to get it to work but they said it wasn't compatible. I'm gonna try to sell that on Ebay with the older unit. Quote Link to post Share on other sites
jhren Posted August 16, 2014 Report Share Posted August 16, 2014 you cant mirror netflix or youtube to the rear via hdmi setup. Its not possible. The REAR ENTERTAINMENT only lets you mirror the head unit dvd, sd. you can use USB, SD, or DVD for the rear. You have to remember your Rear dvd player is setup using the AV cables which is RED YELLOW WHITE. The digital signal will not allow it to mirror. Unless your REAR tv has a hdmi input then its a different story. But the nex will not allow you to mirror from HDMI That doesn't seem right. With the rear display output being composite (analog) and other sources (DVD, SD, etc.) being digital in origination, plus the display being only 800 x 480, confirms the HU already has digital to analog and down sampling conversion capability. I also have to assume with a Mirror setting available in rear display options, the HU is entirely capable of passing HDMI (converted to lower resolution anolog composite signal) to the rear display. The only way I see it not doing so is if it is an implementation of HDCP (High-bandwidth Digital Content Protection). I have to wonder if an RGB connection would remedy the problem. Quote Link to post Share on other sites
Camry8000nex Posted August 16, 2014 Author Report Share Posted August 16, 2014 That doesn't seem right. With the rear display output being composite (analog) and other sources (DVD, SD, etc.) being digital in origination, plus the display being only 800 x 480, confirms the HU already has digital to analog and down sampling conversion capability. I also have to assume with a Mirror setting available in rear display options, the HU is entirely capable of passing HDMI (converted to lower resolution anolog composite signal) to the rear display. The only way I see it not doing so is if it is an implementation of HDCP (High-bandwidth Digital Content Protection). I have to wonder if an RGB connection would remedy the problem. I hope you are right. If you're going to do it let me know if it works Quote Link to post Share on other sites
jhren Posted August 16, 2014 Report Share Posted August 16, 2014 I hope you are right. If you're going to do it let me know if it works I don't have an iPhone or the necessary adapters. I do have the adapters for Android, but my phone doesn't support MHL/HDMI. I am considering purchasing an Android-based HDMI dongle... but its not a definite at the moment. Depending on the when and if, I'll likely start a new thread. If I recall this thread at that time, I'll also post a link here. That's the best I can do at present. Quote Link to post Share on other sites
Camry8000nex Posted December 28, 2014 Author Report Share Posted December 28, 2014 Has anyone figured out a work around. Drives me crazy that I installed a rear mounted screen that I am not using. Quote Link to post Share on other sites
joemamma1954 Posted December 29, 2014 Report Share Posted December 29, 2014 The only workaround, is using HDMI to composite adapter. Hooking up to a/v input, and mirroring a/v. Quote Link to post Share on other sites
Camry8000nex Posted January 11, 2015 Author Report Share Posted January 11, 2015 The only workaround, is using HDMI to composite adapter. Hooking up to a/v input, and mirroring a/v. Nice, anyway you can make a video of how it looks when it's running? Quote Link to post Share on other sites
nyhc77 Posted January 22, 2015 Report Share Posted January 22, 2015 I have figured this problem out guys. I have the AVIC-NEX 8000 and Rockville RHP7 7" headrest monitors. I am able to mirror my iPhone (Netflix, YouTube, whatever...) to the rear monitors and play a DVD, or movies from my SD card to the rear monitors as well. I used an HDMI to A/V adapter with the Apple HDMI to lightning adapter together. I plugged in the video RCA plug from the A/V adapter into the Yellow (V OUT) of the Pioneer. The HDMI end got plugged into the Apple HDMI adapter, and lightning into my iPhone. Even though these monitors are able to use IR wireless headphones I wanted some quality sound through my car speakers so I plugged the red and white audio RCAs from the A/V adapter into the AUX port on the Pioneer using a female RCA to 3.5mm adapter. So if I want good sound from the iPhone to the rear monitors I turn on AUX on the Pioneer. Quote Link to post Share on other sites
Wearethe416 Posted January 25, 2015 Report Share Posted January 25, 2015 I have figured this problem out guys. I have the AVIC-NEX 8000 and Rockville RHP7 7" headrest monitors. I am able to mirror my iPhone (Netflix, YouTube, whatever...) to the rear monitors and play a DVD, or movies from my SD card to the rear monitors as well. I used an HDMI to A/V adapter with the Apple HDMI to lightning adapter together. I plugged in the video RCA plug from the A/V adapter into the Yellow (V OUT) of the Pioneer. The HDMI end got plugged into the Apple HDMI adapter, and lightning into my iPhone. Even though these monitors are able to use IR wireless headphones I wanted some quality sound through my car speakers so I plugged the red and white audio RCAs from the A/V adapter into the AUX port on the Pioneer using a female RCA to 3.5mm adapter. So if I want good sound from the iPhone to the rear monitors I turn on AUX on the Pioneer. Which brand of HDMI to A/V adapter did you use? Quote Link to post Share on other sites
nyhc77 Posted January 29, 2015 Report Share Posted January 29, 2015 This one: http://www.radioshack.com/radioshack-hdmi-to-composite-converter/1500548.html#.VMpDM9LF9EI Quote Link to post Share on other sites
Wearethe416 Posted January 30, 2015 Report Share Posted January 30, 2015 Excellent. How did wire up the two monitors to the NEX? Quote Link to post Share on other sites
nyhc77 Posted February 5, 2015 Report Share Posted February 5, 2015 I used an a/v splitter and ran them to a video RCA plug to the Yellow (V OUT) of the NEX Quote Link to post Share on other sites
