Mosh1 Posted March 9, 2007 Report Share Posted March 9, 2007 Can someone give me a walk-through on burning a background disc onto a single-layer DVD? I used the steps in the sticky, but still no help. Anyone have any ideas? Thanks guys. Quote Link to post Share on other sites
titansu Posted March 19, 2007 Report Share Posted March 19, 2007 The sticky can't be written any clearer... 1. Extract you current NAV disc in .ISO format 2. Browse the .ISO and delete all "POI" files under /IDX/ 3. Replace/add the backgrounds you need 4. Save .ISO 5. Burn Quote Link to post Share on other sites
mk12booze Posted March 26, 2007 Report Share Posted March 26, 2007 anyboby knows if there's a free iso editor software that i can download? thanks Quote Link to post Share on other sites
RSM5483 Posted March 31, 2007 Report Share Posted March 31, 2007 anyboby knows if there's a free iso editor software that i can download? thanksI searched online found MagicISO Maker I beleve it's on download.com if you look there... Most won't allow you to save over 300MB. Unless you buy... Found a serial online It worked for me.... hope I could help you out... Just enter this in after you install it... Name: Alllison M Dekel Code: BTphuy2pnbwGxQE6mLkEOamhuWMFR3aFTSyF4SsLfO67FScJZglzXsWwOcYN3JaSQCc&1JitnAXjnlhEnQySqXogDau7vWccdVJI_LtWnAqMvmA6AOee4Qd7_ZqnI6&RTI__O4KMx_QW_OrR0OzbBphMqZqvwkseMtAKlsCdlI4 Quote Link to post Share on other sites
zride Posted April 1, 2007 Report Share Posted April 1, 2007 How do you make the image file fit on a regular DVD? After I removed the poi files, added mine and saved it the size of the iso was 4.8 gigs and would not fit on a regular dvd. Are there any other files I can remove to reduce the size?? Quote Link to post Share on other sites
action Posted April 2, 2007 Report Share Posted April 2, 2007 Just my .02 but: a) shouldn't you be burning to a CD and not a DVD? I know it works on a CD, but I'm not sure if it works on a DVD. Of course, I have a Z1 so maybe that's the part I'm missing. zride: You must be pretty computer savvy and able to figure this out as your sig looks suspiciously like SQL script. Quote Link to post Share on other sites
zride Posted April 2, 2007 Report Share Posted April 2, 2007 Yeah, you're right, I will figure it out. Just thought you guys had an answer. They say never reinvent the wheel Anyway, for cd's it has to be at least 1.8 megs of data in order to read. It also reads dvds according to the manual -- must be 170 megs i think. Quote Link to post Share on other sites
zride Posted April 3, 2007 Report Share Posted April 3, 2007 By the way, this is for the D3. Does this process even work for the D3?? Here is what it says in the manual When you burn a CD-R/-RW and DVD-R/- RW, make sure the total data size of the CD-R/-RW and DVD-R/-RW is greater than the amount noted below by storing dummy data or other filler information. Otherwise, the disc may not be recognized by the built-in DVD drive. — CD-R/-RW: 1.8 MB — DVD-R/-RW: 170 MB Quote Link to post Share on other sites
JasonH Posted April 3, 2007 Report Share Posted April 3, 2007 You can only burn jpeg CD's for the Z's and N's. With the D's, you have to delete the POI files, and add your custom pim files to the pim2din folder. Quote Link to post Share on other sites
zride Posted April 4, 2007 Report Share Posted April 4, 2007 R U Sure? That's not what the manual states. The manual for the D series (D3) says that you can burn jpeg images to a CD or DVD and it should read it. Quote Link to post Share on other sites
zride Posted April 4, 2007 Report Share Posted April 4, 2007 Figured it out. You CAN record to a CD with JPEG images. you just have to be SURE that there is a /PICTURES folder with <20 jpeg files and that the full size of the disk is >1.8 MEGS thats it. Simple. Done. Quote Link to post Share on other sites
action Posted April 4, 2007 Report Share Posted April 4, 2007 Told ya, you could do it! Quote Link to post Share on other sites
idpbeatz Posted April 14, 2007 Report Share Posted April 14, 2007 anyboby knows if there's a free iso editor software that i can download? thanksI searched online found MagicISO Maker I beleve it's on download.com if you look there... Most won't allow you to save over 300MB. Unless you buy... Found a serial online It worked for me.... hope I could help you out... Just enter this in after you install it... Name: Alllison M Dekel Code: BTphuy2pnbwGxQE6mLkEOamhuWMFR3aFTSyF4SsLfO67FScJZglzXsWwOcYN3JaSQCc&1JitnAXjnlhEnQySqXogDau7vWccdVJI_LtWnAqMvmA6AOee4Qd7_ZqnI6&RTI__O4KMx_QW_OrR0OzbBphMqZqvwkseMtAKlsCdlI4 where did you git it or what did you do to getthis code to work Quote Link to post Share on other sites
idpbeatz Posted April 14, 2007 Report Share Posted April 14, 2007 I just copied all the files except the poi Folder and re burned it to t DVD and worked but now I can't search. Nothing not even map nothing anyboby knows if there's a free iso editor software that i can download? thanks Quote Link to post Share on other sites
PaisanNYC Posted April 15, 2007 Report Share Posted April 15, 2007 Ummm how would you be able to search for anything if you deleted all the POI files? Geez. Just pay the $5 and get a dual layer dvd-r to burn an exact copy! Quote Link to post Share on other sites
