coocho Posted March 13, 2007 Report Share Posted March 13, 2007 I have 06 Linc Zephyr. I don't understand why you can't just switch the thing into night mode regardless of the lights. Do you know what it is that the illumination wire does when on?\ ie. 12volts = on or 0v etc?? yes all it does is give 12volts on, and 0volts off. If you want control over it, you can attach it to ignition and just install a switch. Quote Link to post Share on other sites
Wannabee1989 Posted March 24, 2007 Report Share Posted March 24, 2007 I have a similar issue... on my forester (05) there is a negative and a positive side to the illumination wires. Avic has only one illum. wire... what to do? Quote Link to post Share on other sites
Wannabee1989 Posted March 24, 2007 Report Share Posted March 24, 2007 I have a similar issue... on my forester (05) there is a negative and a positive side to the illumination wires. Avic has only one illum. wire... what to do? Oh... I forget anyone know where to find the vss wire on my car? and what color it is perhaps? Quote Link to post Share on other sites
MisFit Posted March 24, 2007 Report Share Posted March 24, 2007 Speed Sense green/yellow ECM, 20 pin plug, pin 10 The ECM (Engine Control Module) is below the glove box. The VSS wire is also found behind the instrument cluster in the middle plug. Quote Link to post Share on other sites
coocho Posted March 24, 2007 Report Share Posted March 24, 2007 yup yup Quote Link to post Share on other sites
