tdblof Posted April 23, 2007 Report Share Posted April 23, 2007 Does anyone know if the D3 is compatible with the 6 dvd changer....on the pioneer website it says its compatible with "Pioneer Navigation Products such as the z1,z2, and the d2" but it seems like it specifically leaves out the d3......but anywho does anyone know for a fact if these two items are compatible and if so can the changer use the nav discs that way they would always be accesible?? Quote Link to post Share on other sites
whtcrxghst Posted April 23, 2007 Report Share Posted April 23, 2007 The changer cannot use nav disks. The D3 will also not control the dvd changer from the touchscreen, but you could still use it in standalone mode, running the outputs of the changer in through the A/V input on the D3 Quote Link to post Share on other sites
mlammert Posted April 23, 2007 Report Share Posted April 23, 2007 Correct... I looked into this as well... Pioneer's 6-Disk DVD-Changer requires the IP-BUS (which the D3 has) and the AV-BUS (which the D3 does not have)... Apparently, it has two selectable "modes" - INTEGRATED and STANDALONE... If your headunit has both the IP-BUS and the AV-BUS, you can use it in INTEGRATED mode and have full touchscreen control... If your headunit does not have both the IP-BUS and AV-BUS, you can use it in STANDALONE mode where you control the changer via its remote and route the audio/video through an AUX input... Good luck, Mark Quote Link to post Share on other sites
tdblof Posted April 23, 2007 Author Report Share Posted April 23, 2007 well that blows hahaha....so i take it that any pioneer cd or dvd changer will not work with this correct?? i mean fully integrated into the touchscreen...right Quote Link to post Share on other sites
mlammert Posted April 23, 2007 Report Share Posted April 23, 2007 so i take it that any pioneer cd or dvd changer will not work with this correct?? No, that is not correct... I am currently running Pioneer's 12-Disk CD-Changer through my D3 and I have full touchscreen control of the 12-Disk CD-Changer... The 12-Disk (and 6-Disk) CD-Changers only require the IP-BUS... The touchscreen control of the 12-Disk is sweet... You have a scrollable menu of disks (six per page - just like presets) on the left side of the screen... On the right you have your play/pause, track forward/backward, etc... On the top of the screen it tells you the current disk and track number and remaining time I believe... Disk swaps are VERY fast in my opinion... I am very happy... Good luck, Mark Quote Link to post Share on other sites
tdblof Posted April 23, 2007 Author Report Share Posted April 23, 2007 thank you very much and just one last question does the changer have cd text capability??? i know it doesnt have mp3 Quote Link to post Share on other sites
mlammert Posted April 23, 2007 Report Share Posted April 23, 2007 No problem at all... Yes, the 6 and 12-Disk Changers have CD-TEXT capabilities... I have verified this on a couple of my CD-TEXT disks that I own... Good luck, Mark Quote Link to post Share on other sites
necro Posted April 24, 2007 Report Share Posted April 24, 2007 Before you get too jumpy, you should note that the CD changers work fully, but not the DVD changers. Quote Link to post Share on other sites
tdblof Posted April 24, 2007 Author Report Share Posted April 24, 2007 aight sweet yeah im gonna have to invest in the 12 disc cuz its only like 30 bux more then the 6.....i also have the d3 installed in my 03 acura tl-s it was done at a shop in my area and if anyone has any questions on what it may look like in case they have an acura like that ill be happy to post pics Quote Link to post Share on other sites
