ryan0240 Posted May 23, 2007 Report Share Posted May 23, 2007 heres my code: pup21-gsrga-5hauz. has not been used yet! Quote Link to post Share on other sites
robbieg Posted May 25, 2007 Report Share Posted May 25, 2007 Here's another fresh one! ph9e5-y2xbz-r9uwj Quote Link to post Share on other sites
VBLUE42 Posted May 26, 2007 Report Share Posted May 26, 2007 Mine's still valid on the first page. Quote Link to post Share on other sites
shmakdawg Posted May 26, 2007 Report Share Posted May 26, 2007 im tryna order a bluetooth module from crutchfield but cant figure out where to put these codes in. what am i doing wrong. and what is it that you get by using the codes? Quote Link to post Share on other sites
VBLUE42 Posted May 26, 2007 Report Share Posted May 26, 2007 Add to cart, then at the box to the right that says SPECIAL OFFER put the code in. Use mine of course: ps514-0aspb-y4euy That should do it. Quote Link to post Share on other sites
VBLUE42 Posted May 26, 2007 Report Share Posted May 26, 2007 Also, under the BILLING & SHIPPING section of your order, look under OTHER PAYMENT METHODS at the bottom for CRUTCHFIELD REFERRAL CREDIT. That might do it as well ps514-0aspb-y4euy Quote Link to post Share on other sites
shmakdawg Posted May 26, 2007 Report Share Posted May 26, 2007 dude i found it on the billing section but its asking me for a name and zip now. what exactly will i get by using this? Quote Link to post Share on other sites
VBLUE42 Posted May 26, 2007 Report Share Posted May 26, 2007 20 bucks off. My name is Michael and my zip is 39565 Quote Link to post Share on other sites
shmakdawg Posted May 26, 2007 Report Share Posted May 26, 2007 need last name Quote Link to post Share on other sites
VBLUE42 Posted May 26, 2007 Report Share Posted May 26, 2007 PM sent!!! Quote Link to post Share on other sites
shmakdawg Posted May 26, 2007 Report Share Posted May 26, 2007 ok whats going on is, you to buy a minimum of $200 worth of stuff for it to work. thats my problem right there. if i decide to pick somethin else up ill def use your code bro. thanks for all the help. Quote Link to post Share on other sites
VBLUE42 Posted May 26, 2007 Report Share Posted May 26, 2007 No problem, thanks Quote Link to post Share on other sites
drgilani Posted May 31, 2007 Report Share Posted May 31, 2007 Never used before p36fx-48b3a-d70cr Use it. 20$ credit off ur order. Quote Link to post Share on other sites
joebanks Posted August 5, 2007 Report Share Posted August 5, 2007 Here is my referral code ph3aw-xk6pu-vsq2v It should be valid since it has never been use Quote Link to post Share on other sites
hotwheels Posted August 9, 2007 Report Share Posted August 9, 2007 Chris here is my code never used in 4 months Quote Link to post Share on other sites
