Need help with Navigation
I had the same problem with my dvd80 hooked up to a 5700dvd. I was using a burned copy of the navigation disk. Turned ouot to be the disk. Are you using a burned copy? If so try the original and see if you get the same error!
Hope this helps. :D
The Z2 does't have or use discs. It is all on the internal harddrive.
