bcdal Posted June 28, 2007 Report Share Posted June 28, 2007 I'm adding the XM tuner (GEX-P10XMT) to my Z1 that already has a tv tuner (GEX-P5700TV) attatched by ip-bus. I keep looking at the connection daigram, but I'm not quite sure how to follow the "daisy chain" process. Do I make a complete loop through all components? or is it a one way connection? I know it shouldn't be this confusing. I believe I have the 5700 "looped" in that I have one cable to the 5700, and another one coming back to the Z1. If so, I guess it wouldn't matter waht order they are in. Any help would be much appreciated. *** EDIT: okay...I see I have an AV-BUS between TV tuner and Z1. Would this be part of the chain? *** Quote Link to post Share on other sites
BigFloppy Posted June 28, 2007 Report Share Posted June 28, 2007 IPBus (Z1) -> GEX-P10XMT (output) GEX-P10XMT (Input) -> GEX-P5700TV (Output) OR IPBus (Z1) -> GEX-P5700TV (output) GEX-P5700TV (Input) -> GEX-P10XMT (Output) OR Give me your GEX-P5700TV because you can;t seem to wire it up properly and you think you'll never get it working (I will pay the shipping if you want me to ) Your AVBus doesn't form part of the equation Quote Link to post Share on other sites
bcdal Posted June 28, 2007 Author Report Share Posted June 28, 2007 Thank you! I'm gonna give it a try tonight. I guess I thought the AV-Bus was part of it. It's simply a chain of IP-Bus connections. Thanks again...and I'll keep the 5700 for now Quote Link to post Share on other sites
