nodnarb901 Posted June 30, 2007 Report Share Posted June 30, 2007 Just wondering if you can plug up and iphone to the Pioneer ipod adapter and still listen to all of your songs through the avic d1? Don't want to do anything else through the adapter just listen to music. Quote Link to post Share on other sites
Sandboy Posted June 30, 2007 Report Share Posted June 30, 2007 Yes music does word with the D3. I'll write up full details later today. Quote Link to post Share on other sites
Sandboy Posted June 30, 2007 Report Share Posted June 30, 2007 Ok heres what I have found. The D3 and the iPhone will work but VERY limited. You can play music on the D3 with the iPhone but there is no way to get the video output to work. Also the D3 will not charge the iPhone. I don't have a bluetooth connection for the D3 so I cant check the phone connection but I would assume it should work as it is just bluetooth. My hopes are they will give us a new DVD with an update for the D3 so it will better support the iPhone. I tried a few work arounds to get the charging to work but none of them seam to actualy charge the iPhone. Quote Link to post Share on other sites
jlpinedas Posted May 11, 2008 Report Share Posted May 11, 2008 The bluetooth works perfectly fine with the iphone. The only thing is if you are listening music and someone calls you and that person ends the call, the d3 will resume the song previously be played, but if you end the call it will resume the song for 3 secs and then it'll stop playing. You just need to press play on your d3. Quote Link to post Share on other sites
hansfj40 Posted May 17, 2008 Report Share Posted May 17, 2008 well i know for a fact the d3 does charge the iphone. there is a box you can check if you want to turn charging on or off. i dont understand why it wont play the video off my iphone. as for ending a call when someone calls, it does but as soon as i hang up it resumes. there is a setting on the iphone to change it. Quote Link to post Share on other sites
bodacious Posted December 30, 2008 Report Share Posted December 30, 2008 well i know for a fact the d3 does charge the iphone. there is a box you can check if you want to turn charging on or off. i dont understand why it wont play the video off my iphone. as for ending a call when someone calls, it does but as soon as i hang up it resumes. there is a setting on the iphone to change it. Where is this box that would allow me to charge my 2G iphone w/the D3? I get the "accessory" error message when I hook the iphone up to the D3 using the ipod connector. I also read that the D3 would fry your iphone. Thanks for the info. Quote Link to post Share on other sites
bodacious Posted December 30, 2008 Report Share Posted December 30, 2008 After recieving that "accesory" message this morning, I got the iphone to work thru my D3. The only thing it will not do is play video from the iphone. Quote Link to post Share on other sites
