nothing Posted July 31, 2007 Report Share Posted July 31, 2007 what is the procedure to do an HD backup before doing the bypass? does it need to be unlocked? and if so do you have to relock it? is it a simple matter of connecting to a laptop or something and doing a drive image with ghost or acronis? TIA Quote Link to post Share on other sites
ducatiboy Posted July 31, 2007 Report Share Posted July 31, 2007 what is the procedure to do an HD backup before doing the bypass? Ok, here comes the hand holding.... It's all in the sticky in this section: http://www.avic411.com/forum/viewtopic.php?t=728 does it need to be unlocked? Yes, it's about $50. and if so do you have to relock it? No, I would recommend disabling the relocking in case you want to hook it back up again to the PC. is it a simple matter of connecting to a laptop or something and doing a drive image with ghost or acronis? PC not a laptop. The unlock software needs it to be hooked to the secondary master IDE connector (with an adapter). Tough to do that in a laptop. Yes, you can use either of those. TIA After following the info in that post above, back it up as you would any other drive. If you like Acronis or Ghost, whatever... Quote Link to post Share on other sites
nothing Posted July 31, 2007 Author Report Share Posted July 31, 2007 awesome reply!!! thanks so much Quote Link to post Share on other sites
