Guest Posted July 4, 2006 Report Share Posted July 4, 2006 I took a road trip from AZ to CA and everything worked fine on the way down. Today on the way back i got into LA and all of a sudden my screen showed me flipping a U-turn on the free way and then doing a circle and going off into oblivion. I pulled off and when into the connection status setup to see how many satellites it has.... upon opening up that screen I got prompted with the message, "satellite antenna not conection, please check connection". I want to know if anyone else has expeirenced this? I am going to pull out my deck and check to see if maybe the antenna didn't work itself out of the terminal in the back from all of the bumps (still suspension on an STI). Thanks for the heads up everyone... if indeed the antenna is bad... where can I get a new one? Part number? Any help appreciated. Thanks Quote Link to post Share on other sites
03Aviator Posted July 4, 2006 Report Share Posted July 4, 2006 The antenna has a pretty solid connection. Unless it wasn't seated all the way when installed, I can't believe it worked it's way out. Quote Link to post Share on other sites
Guest Posted July 4, 2006 Report Share Posted July 4, 2006 Yeah that is what I was thinking too... but the only reason why I suspect that is because when I was installing it I distinctly remember questioning if the antenna was connected connectly becasue it doesn't have a very positive seat when plugging it in. I live in AZ and it has been between 110-115 the last month and I figured that it would have crapped out sometime then if they are "heat sensitive". It wasn't over 100 on the way home, just extremely bumpy so it is my only idea.... I tapped and tapped and jared the antenna and nothing... I will look into it... in case it matters... it is in the top right of my dash in the bottom corner of my windshield. Thanks... I will keep you all posted Quote Link to post Share on other sites
jvcjbl Posted July 4, 2006 Report Share Posted July 4, 2006 Oops... just realized that I haven't been logged in when posting... oh well... well I pulled out the tv and reseated the antenna connector and all is well... I got reminded why I suspected the antenna in the first place... when I first installed the unit I pushed in the antenna and waited for the "click" you normally hear when seating those connections... I never got that.... so I pulled on the cable lightly and it came right out... so I just seated it in there really well and moved on... same thing is still happening... the connector never really locks in place... it is tight but I know it can (as it did) move out of place losing connection. Anyway... I will call pioneer and see if they will warranty the antenna... Thanks Quote Link to post Share on other sites
03Aviator Posted July 5, 2006 Report Share Posted July 5, 2006 Yep. Doesn't sound like it's hooking right. It was hot this June here wasn't it. I just heard it was the hottest June on record. That's why my garage is air conditioned!!! :lol: Quote Link to post Share on other sites
Guest Posted July 5, 2006 Report Share Posted July 5, 2006 Yeah not too bad... I think the highest I saw my car record was 115'. Too bad it is f-ing raining here... I just washed/waxed my car yesterday. Oh well... Quote Link to post Share on other sites
