GarrettF Posted August 25, 2007 Report Share Posted August 25, 2007 My battery in my car is a little weak and i think that is the problem but I was just wondering if anyone else had exericed the unit not retiain prests for XM and AM/FM? Quote Link to post Share on other sites
whtcrxghst Posted August 25, 2007 Report Share Posted August 25, 2007 Make sure you have the constant wire hooked up properly Quote Link to post Share on other sites
GarrettF Posted August 27, 2007 Author Report Share Posted August 27, 2007 the unit rememebrs the angleof the screen but not the presets, but i will check the constant power wire Quote Link to post Share on other sites
Two_Cold Posted August 27, 2007 Report Share Posted August 27, 2007 Weak ground, weak constant power, weak battery. Could be any one, or a combination of. Quote Link to post Share on other sites
GarrettF Posted August 31, 2007 Author Report Share Posted August 31, 2007 does the XM receiver need to be hooked up to constant power? Quote Link to post Share on other sites
GarrettF Posted September 4, 2007 Author Report Share Posted September 4, 2007 bump - does the XM unit need to be hooked up to constant power for the headunit to keep memory? Quote Link to post Share on other sites
