Jeeper Posted September 7, 2007 Report Share Posted September 7, 2007 Has anyone else had a problem with the sound cutting out? I accidentally fixed the problem by flicking the headlights on for a second. The sound came back. This has happened three times now at seemingly random times. This, of course, is in addition to the "heat freeze"... What a piece of crap. If Pioneer hadn't spent so much time and effort locking the unit down while you are driving maybe they would have had a little left over to make sure the unit actually functions properly. Quote Link to post Share on other sites
MisFit Posted September 8, 2007 Report Share Posted September 8, 2007 if you spent a little more time telling us what kind of car you have, maybe we could help you Quote Link to post Share on other sites
Jeeper Posted September 8, 2007 Author Report Share Posted September 8, 2007 07 Jeep wrangler with infinity system Quote Link to post Share on other sites
MisFit Posted September 8, 2007 Report Share Posted September 8, 2007 and what wiring harness did you use? Quote Link to post Share on other sites
Jeeper Posted September 8, 2007 Author Report Share Posted September 8, 2007 There was only one out that would work when I installed it, the Metra CHTO-03. Thanks for the help. Quote Link to post Share on other sites
MisFit Posted September 8, 2007 Report Share Posted September 8, 2007 yep, thats the right one to have used. sounds like its either a defective mod or just wired wrong Quote Link to post Share on other sites
DaveK52 Posted May 10, 2008 Report Share Posted May 10, 2008 Jeeper...did you ever resolve this problem? I have an 08 Wrangler that has the whole right side cutting out, coming back in, cutting out again, etc. Same system as you...factory infinity system. Install was done by a professional shop. My jeep is there now with them. Quote Link to post Share on other sites
Jeeper Posted May 10, 2008 Author Report Share Posted May 10, 2008 Dave, I did end up solving the problem, however not in the fashion that will help you. I ripped the system out, sold it on eBay, and replaced it with the Kenwood 7100. Between the heat freeze, the sound cutting out, the lockdown while moving, and Kenwood has a much better GPS interface (Garmin, my #1 feature), I just got rid of it. The Kenwood has run crash free for 6 months. However, before getting rid of the system, I never found out what was causing the sound to cut out. As noted earlier in the thread, flicking the headlights on and back off seemed to work. It's like something is shorting between the dimmer switch inside the unit and the sound??? I am not an expert, just a frustrated user. Quote Link to post Share on other sites
