Adrian101 Posted June 27, 2015 Report Share Posted June 27, 2015 I am trying to install two updates from the pioneer website for my F940BT - I downloaded and extracted everything indivdually as directed and when i have tried to install i get the SD version displayed as “--------†which according to pioneer means that the "data on the SD memory card or microSD card may be corrupted. Please repeat the firmware download and installation process" I have then reformated the SD card and tried again a number of times (making sure there is only the update folder and file located within the root folder) but still have the same problem - Is there something i am not doing correcly or is there a glitch within software downloaded using winzip? Quote Link to post Share on other sites
BlakeStone Posted June 27, 2015 Report Share Posted June 27, 2015 the sd card is a sticky issue. sometimes you get lucky and it works and sometimes you just have to specifically do a full format to fat32 with the 16k allocation unit size specifically selected. if you have to unzip anything, unzip to a folder on your computer and then do a copy to the sd card. hope this works for you. Quote Link to post Share on other sites
