JLiRD808 Posted June 15, 2016 Report Share Posted June 15, 2016 About 1/6th the time I start my car, I get a bad screen on my 4100NEX (see pics). Restarting the car will usually fix it, though it happened 4x in a row yesterday so I'm pursuing this further. To add more info, it seems the unit is still functioning in the background. Music will still come on (whatever was playing last), and I can still navigate menus slightly via my memory of where buttons are supposed to be located. I can hear it BEEPING when I tap buttons. If I start my car and the screen loads normally....everything is fine! My unit is only about a month old. I've spoken with the shop that sold and installed it. Is this due for a replacement or can it be repaired? Thanks! Quote Link to post Share on other sites
asd255 Posted June 16, 2016 Report Share Posted June 16, 2016 1. Check the FFC connection between Monitor Unit (CN2704) and IF Unit (CN8401). 2. Try to remove and re-insert above FFC (Both side of connectors). Check whether FFC is not inserted completely to the connector (Slanting insertion). Check whether there is no foreign object in the connectors. Quote Link to post Share on other sites
Cmatt1271 Posted June 27, 2016 Report Share Posted June 27, 2016 About 1/6th the time I start my car, I get a bad screen on my 4100NEX (see pics). Restarting the car will usually fix it, though it happened 4x in a row yesterday so I'm pursuing this further. To add more info, it seems the unit is still functioning in the background. Music will still come on (whatever was playing last), and I can still navigate menus slightly via my memory of where buttons are supposed to be located. I can hear it BEEPING when I tap buttons. If I start my car and the screen loads normally....everything is fine! My unit is only about a month old. I've spoken with the shop that sold and installed it. Is this due for a replacement or can it be repaired? Thanks! Did you ever find the solution to this? My nex 5100 is doing the same thing as your first photo shows, the left half of the screen is blank, but right still shows normal screen. Left side is still responsive to touch but doesn't display anything. My unit is just 4 months old and installer is looking to get me a replacement unit. Quote Link to post Share on other sites
