CrazyCowPie Posted September 19, 2007 Report Share Posted September 19, 2007 From what I've read, if I install Avic-Z2 and download the 30MB file in the sticky post for Z2 bypass; all I need to do is insert this CD and upgrade the Z2, then do the 2 wires grounding and I'm good to go with the video bypass? Thanks for any input! Quote Link to post Share on other sites
whtcrxghst Posted September 20, 2007 Report Share Posted September 20, 2007 Yes. If you happen to buy one that was manufactured after sometime in July, it will already have that file in it to allow it to be bypassed so you won't need to bother Quote Link to post Share on other sites
CrazyCowPie Posted September 20, 2007 Author Report Share Posted September 20, 2007 Alrighty then...thanks! Take now, bye bye then Quote Link to post Share on other sites
Bob_CV Posted September 20, 2007 Report Share Posted September 20, 2007 Yes. If you happen to buy one that was manufactured after sometime in July, it will already have that file in it to allow it to be bypassed so you won't need to bother Just to confirm, if the unit was manufactured before July (mine was May 2007), then I will need the 30Mb .iso file. Correct? Quote Link to post Share on other sites
whtcrxghst Posted September 20, 2007 Report Share Posted September 20, 2007 Yep. Unless someone did it already Just to confirm, if the unit was manufactured before July (mine was May 2007), then I will need the 30Mb .iso file. Correct? Quote Link to post Share on other sites
Bob_CV Posted September 20, 2007 Report Share Posted September 20, 2007 Yep. Unless someone did it already Nope... Just recieved the unit this week and will be installing tomorrow. Thanks for the info! Quote Link to post Share on other sites
CrazyCowPie Posted September 21, 2007 Author Report Share Posted September 21, 2007 If the Z2 unit does not needed, but one use the 30mb file update anyways, would that hurt the Z2? TIA! Quote Link to post Share on other sites
whtcrxghst Posted September 21, 2007 Report Share Posted September 21, 2007 No. It will just give you a prompt that its already done If the Z2 unit does not needed, but one use the 30mb file update anyways, would that hurt the Z2? TIA! Quote Link to post Share on other sites
