Z2inM3 Posted October 26, 2007 Report Share Posted October 26, 2007 I would appreciate your help as I need to determine if I have to order a http://www.sminntech.com/z1flasher.html in order to run my radio. I have a May 06 Z1 so normally I would need the flasher to run unlocked. I plan on buying an upgraded HD with the Z2 software. Would I still need to use the flasher or will the 2 wire bypass work? I am not sure if there is a hardware difference between the build or was it just software on the HD. Thank you in advance. Peter Quote Link to post Share on other sites
installermarc Posted October 26, 2007 Report Share Posted October 26, 2007 Should only need the 2 wire bypass after the Z2 upgrade. If it were me, I would wait until then. Quote Link to post Share on other sites
whtcrxghst Posted October 30, 2007 Report Share Posted October 30, 2007 You don't need to buy anything. Just do the bluetooth update to your Z1 and it will be bypassable via the 2-wire method like the Z2. Then you won't have to pull the deck out when you swap HDs since the bypass will already be done Quote Link to post Share on other sites
Z2inM3 Posted October 31, 2007 Author Report Share Posted October 31, 2007 Is this the update referred to as the Bluetooth update. http://www.pioneerelectronics.com/pna/v ... 48,00.html Quote Link to post Share on other sites
whtcrxghst Posted October 31, 2007 Report Share Posted October 31, 2007 No, that is to fix heat issues. Bluetooth update was a disk sent out by Pioneer and then posted here: http://avic411.com/forum/viewtopic.php?p=19463 Is this the update referred to as the Bluetooth update. http://www.pioneerelectronics.com/pna/v ... 48,00.html Quote Link to post Share on other sites
