Lu Scola Posted November 9, 2007 Report Share Posted November 9, 2007 Ok I installed a D3 in a 2003 Denali w/BU-cam. Truck has factory rear A/V Entertainment DVD/TV in one dropdown that still works. It also has RCA input for video 2. Now if you are familiar with Denali you know there is a 6 disc din size cd changer in lower center dash area. so I am gonna put a 7" flip out screen. So here is how I am gonna run that. 1. DVD in and out from and to D3. so both units can play on each other. 2. Run AV outs to the rear factory t.v by RCA Y-cables. 3. Also run Y-splits out into a 15" Dropdown going into 3rd row ceiling area NOW THE QUESTIONS I HAVE: I have rewired kickers in all 4 doors with speaker wire out of harness independtly to the head unit. 1. Can I tap into the speakers going into the D3 and run them also into the second flip out tv in lower dash, leaving option of turning up volume on either unit. I would only use one at a time of course? 2. I have a 6 disc Pioneer FM modulated changer. I just bought a regular Pioneer Changer cable that has power cables running with them. Will this wire conver the changer into a regular changer being able to be controlled by D3 instead of the little FM mod cable and controller. Any help would be appreciated fast because I am gonna hook all thesde up tommorrow or sat. Quote Link to post Share on other sites
hottwhyrd Posted November 9, 2007 Report Share Posted November 9, 2007 NO AND NO UNLESS THE CHANGER HAS A SQUARE PBUS CABLE ON IT Quote Link to post Share on other sites
Lu Scola Posted November 9, 2007 Author Report Share Posted November 9, 2007 On the first question I dont see why not, and you give no explanation y not. The speakers are not thru the wiring harness, so why couldnt I run the into 2 head units. As long as there both not turned up at the same time. can anyone give a more detailed answer on this. BTW the FM MOD cable does remove from changer and i believe it is i-bus Quote Link to post Share on other sites
whtcrxghst Posted November 9, 2007 Report Share Posted November 9, 2007 Changer should work fine if you bought a new P-bus cable Quote Link to post Share on other sites
Lu Scola Posted November 9, 2007 Author Report Share Posted November 9, 2007 Changer functions great, removed the controller unit and add i-bus cable. Now the task of wiring up the second head unit in lower console, with speakers going into both units. Quote Link to post Share on other sites
