skicrave Posted November 28, 2007 Report Share Posted November 28, 2007 Within the last week my Z1 has started to boot excruciatingly slow. It never actually freezes, and will eventually end up in the UI, so I don't think it's the same problem that others have been having. But whereas before it would take maybe a minute from when I turned on the car until I was at the disclaimer screen, now it takes close to five minutes. I haven't tried a reset yet for fear of wiping out all of my contacts, but I will if that will help. Has anyone encountered this before? Quote Link to post Share on other sites
whtcrxghst Posted November 28, 2007 Report Share Posted November 28, 2007 Nope. I would try the freeze fix just in case. Can't hurt anything and if it doesn't work you know you have a HD problem Quote Link to post Share on other sites
skicrave Posted November 29, 2007 Author Report Share Posted November 29, 2007 Okay, I'll try that fix and see what happens. Quote Link to post Share on other sites
S.F.W. Posted November 30, 2007 Report Share Posted November 30, 2007 If you can pull out the Hard Drive and scan it for bad sectors. Could be a bad hard drive. Quote Link to post Share on other sites
meb9796 Posted December 3, 2007 Report Share Posted December 3, 2007 When I've disconnected my battery to do other work, sometime my Z1 will boot up slowly until I reset it. Unfortunately I don't have the bluetooth module, so I can't tell you if you'll loose all your contacts. I know I didn't loose my radio and xm presets if that helps. Good luck Quote Link to post Share on other sites
