Unresolved Issues (After Firmware Update)
By njohnston · Jul 23, 2008in Problems/Troubleshooting💬 54 posts👁️ 15,327 views
Page 3 of 3
Posted Aug 25, 2008 · 21:56 UTC#51
Do you really need to put the same post in every single thread you kind find, Lou?
Posted Jan 08, 2009 · 20:52 UTC#52
If anyone plays music/videos from sd card,
fast forward does not work... search on videos is nice tho.
When set to random mode, pressing next song goes to the next song in list not next random song
Pull down bar on side used to work and does not anymore. How can you search your song library? They could make this wider as well so it would be more useful. A song search feature would be good too.
No directory listing for videos.
There is no fit to screen feature for videos.
Videos from my zen appear very small.
Sound levels could be normalized as some sound files are very loud and some are very quiet.
You need to go through menus to get to an EQ when it should be one button away
SD card when removed is recognized immediately, but it does not recognize a new card when put in like it should. It would be nice to be able to keep various cards and just change them, but it doesn't work right.
Plugging in my flash drive seems to cause huge problems like massive unresponsiveness, or freezing.
Card loading speed could be improved
Would also like to see play list files so I could make up my own play list... or at least have it recognize winamp play lists.
Aside from navigation, the SD slot and usb ports were huge motivators for my purchase. I would like to see them supported better.
If only the programing could be improved a bit, I would be so much happier with my system.
What is the best way to contact Pioneer about my set of issues? It would be nice if they know about them to fix them.
Posted Jan 10, 2009 · 00:21 UTC#53
European version post 2.0010 and bluetooth 3.30 bugs:
1- Bluetooth hiss noise while making a call
2- Frequent sound losses while talking on bluetooth
3- Names noıt displayed if second calls received when talking.
4- Calls drop occasionally when second calls are received.
5- A chime sound occasionally sounds when a call is received
6- SMS Message warning is not displayed (using nokia 6110 navigator)
6-Red arrow moves out of screen and doesn't show until map button is re-pressed
8- When USB Flashdisk is used bootup time and keypresses slow down.
9- When USB Flashdisk is used keypress volumes are lower. They increase if USB disk is detached.
10- Voice Recognition disabled in EU units.
11- Can't we have cover art displayed in USB/SD mode as well?
12- Can't we use playlists in USB/SD mode as well?
13- We need cancel route, poi icons on the main map
14- 3D angle is oddly different to PDS versions. They even see mountains and skies but we can't.
15- Updated version of I-Go to 8.3.2
16- Updated maps (2008-2009?)
17- Keypress lags still exist
18- Slow bootup time
19- Preset stations up and down is jumpy due to lag.
20- Audio outs are unbalanced. Maps sounds are adjustable however radio, music from SD/USB and IPOD, CD and DVD sounds are all at different levels. You can never find an overall harmony between these so keep turning the volume up and down.
21- Bluetooth phone connect times vary
22- Tried stormax 16gb and corsair 8gb usb flash disks ansd they are not recognised.
23- An export/backup function for user created files such as favourites, pois, phonebook, search criteria to avoid data loss during updates.
24- "dead reckoning" option working rather than "gps signal lost" as announced in the launch of F series.
25-More color options then pioneer red and blue
26- Custom skins support
Posted Jan 19, 2009 · 06:19 UTC#54
Hi,
I wonder if anyone has had problems with "Dead Reckoning" on the F900BT? I just got a F900BT installed recently, the installers say that the VSS has been connected, so the Dead Reckoning should work when I don't have a GPS signal...
BUT, when I enter a tunnel or a building (or in the city with tall buildings), once I loose the GPS signal, the unit will say "GPS Signal Lost" and then stop reporting my position and speed. (arrow goes grey, etc)
Seeing the quote above from alien2000a made me think if this might be a software problem?
I have version 2.00000 firmware on my unit... (ver 2.0010 is not available for my region - Australia yet)
Has anyone else experienced similar problems with Dead Reckoning and got it resolved by a firmware update?
BTW, is there a way to tell if the VSS connection is working?
Page 3 of 3
