AVIC "F" Series Bypass (Picture Guide)
By Wizzard005 · Aug 07, 2008in Hacks/Mods💬 336 posts👁️ 357,899 views
Page 8 of 14
Posted Apr 17, 2009 · 05:35 UTC#176
It might be something pioneer put in there just FOR a bypass, like if you were installing the unit as a demo in a store you would ground the 2 wires and be fully fuctional OR if you are installing the unit in a diff place in the vehicle other then the dash (thinking RV or sleeper area of a truck, or something like that). OR they could have just realized that they would sell more if there WAS a way for the end user to bypass the safety features but thy could not just ship them bypassed from the factory due to laws in most states.
Posted Apr 17, 2009 · 09:37 UTC#177
the pin is labeled "kmode" .... its not some kind of fluke that grounding that pin enables the bypass.
Yes I was just wondering what else putting the AVIC in "K mode" might do.... while trying to decide whether to do hardware of software bypass :) Thanks for looking it up though!
Posted Apr 17, 2009 · 23:08 UTC#178
Let me understand all of what I have read since December. If I have the software bypass all I need to do is ground my parking brake, or do I need to do the full hardware bypass? I am learning so please forgive my ignorance.
Posted Apr 17, 2009 · 23:11 UTC#179
if you have the software bypass all you have to do is ground the break wire, but be aware that if/when pioneer updates the firmware you might loose the software ability to do a bypass, but till then you are set.
Posted Apr 18, 2009 · 00:06 UTC#180
Thanks for that information
Posted Apr 21, 2009 · 21:03 UTC#181
I have reasons to believe that hardware bypass mentioned in this sticky topic has a bad side effect: draining the car battery.
I recently installed an AVIC-F900BT in a Volkswagen Passat 2009. I used a Connects2 CTSVW002 canbus adapter to connect the unit to the radio connector of my car. The canbus adapter provides acc power, illumination, speed signal and parking brake wires to ease the install, as well as an interface to the steering wheel control buttons. I opted for doing the hardware bypass as described in this thread.
The first couple of weeks after installing the AVIC-F900BT I used the car almost daily. Then, when I tried to unlock the car after it had been parked for about a week, the battery was dead. Bummer! I immediately suspected the car radio to be the source of the problem. In order to find out, I hooked up an amp meter between the negative connector of the car battery and the negative battery cable when the car was in power saving mode. Then, I disconnected the AVIC and did the same measurement.
Both AVIC-F900BT and Connects2 canbus adapter disconnected: 5.5 milliamps
AVIC-F900BT and Connects2 canbus connected with hardware bypass: approx. 120 milliamps!!
I sure found the source of my flat battery! I tried to undo the hardware bypass and -- voila! -- current draw is down to approx 12 milliamps.
Has anyone else experienced this? Maybe the hardware bypass is not a smart thing to do after all?
Posted Apr 21, 2009 · 21:51 UTC#182
I'll bet you didn't disconnect the parking brake wire from the canbus adapter before you grounded it. (You ground the wire from the AVIC, not the wire from the canbus.)
Done correctly, the bypass does not cause any excess drain.
Posted Apr 22, 2009 · 07:24 UTC#183
I never connected anything to the parking brake wire coming from the canbus adapter. The green parking brake wire coming from the AVIC was connected to the black ground wire in the harness together with the mute wire coming from the bypass position as described in this thread.
Any other idea why the bypass might cause current drain?
Posted Apr 22, 2009 · 13:23 UTC#184
Mute wire moved to wrong position. (This is probably not it if the bypass was working correctly.)
Defective AVIC.
Posted Apr 22, 2009 · 14:43 UTC#185
Defective AVIC.
The bypass was working correctly. And I also double and triple checked that the mute wire was moved to the correct position in the connector.
Is there a difference between European and American AVIC units? I was told by a local install shop here in Norway to just connect the parking brake wire in the AVIC harness to ground (and leave the mute wire unconnected in its original position). This seems to work perfectly without any current drain.
Posted Apr 23, 2009 · 02:25 UTC#186
Apparently, there is a difference between the European and American versions. The American version gives a warning about the parking brake being improperly connected if the mute wire is not moved and grounded.
Posted May 17, 2009 · 20:33 UTC#187
I just installed and bypassed my f900bt in my RSX. I want to thank everyone who participated in the forum and made it so easy for the rest of us. The only reason i bought the f900bt was because every1 on this forum made it
Herez what i did, and it worked like a charm.
1) replaced the mute wire from its original position to the 4th position on the other side. But left it un-connected (just tapped up)
2) Grounded the Parking brake wire to the cars' ground( black wire).
3) Turned on the system. I now had all 4 settings options (navi settings, system settings, av sound settings, av settings)
- if you dont ground the parking brake wire you will only have 2 opions enabled (navi settings and system settings are disabled)
4) navigate to system settings and calbirated the screen by using the Stylus.
5) copied the 2 folders in testmode.zip found on the wiki of this forum onto a SDCard.
6) installed the SDcard in the f900bt and restarted the sytem.
5) When the system comes up in test mode, It takes a minute to copy a few files and then a dialog box opens up on the screen that covers the whole screen.Used the stylus to click the 'X' on the right top.
6) using Explorer browsed to MY Flash drive and copied it to my SDCARD.
7) modified the pioneer.ini file in data.zip on my laptop (using WINRAR- i have read people say Winzip is not the same and may corrupt the DATA.zip, so stick to Winrar).
8) put the SD card back in the system and booted the sytem. clicked the 'X' on the dialog box. used explorer to take a backup of the original DATA.zip by renaming it and then copied the altered DATA.zip over.
9) Restarted the system and HELL YA bypass was done.
Posted May 18, 2009 · 20:23 UTC#188
Why didn't you just ground the Mute wire? Moving it without grounding it doesn't do anything. It would have saved you from the software mod entirely.
Posted Jun 01, 2009 · 02:32 UTC#189
What exactly is the purpose of the Mute wire? by grounding it, it will have no use, so im curious what use does it have before its grounded that im not going to have access to once its grounded?
Posted Jun 01, 2009 · 08:12 UTC#190
Before the days of bluetooth, wired car phone adapters used the Mute wire to tell the audio system to quiet down so that you could take a call. Most modern phones connect via bluetooth and use that instead. The hardware mod involves moving what was used as the Mute connection to a different pin on the radio. This pin, in combination with the parking wire, can be grounded to disable the code that keeps you from mucking with GPS settings/viewing video/etc, while the car is moving.
Posted Jun 02, 2009 · 03:02 UTC#191
well i replaced the mute wire while i was preparing the harness. The hack worked even without grounding the mute wire, So i just let it be.. Besides i remembered that someone in the forum said no matter what you have to remove the mute wire from its original position .. so i just followed suite..
Posted Jun 02, 2009 · 03:46 UTC#192
what about the annoying error messages? did that get rid of them too?
Posted Jun 07, 2009 · 00:45 UTC#193
I quickly saw my oversight after I took out my radio and took another look.
** Bypassing is easy, just follow the guide **
The mute wire is moved FROM the corner location TO THE 4th position-in on the opposite row of the SAME header, correct???? I followed the 2 pics in the instructions but get an error message when I drive too,
This mod doesn't work with f90bt v2.0 software maybe.
................................please help?
I'll try installing the test mode software next to see if that works, looks like you can only edit the speed settinf using winrar? after extracted the files and looked through the folders, no pi0neer ini file exists.
My PC doesn't have an sd card reader either!
any help.............................
Posted Jun 12, 2009 · 04:35 UTC#194
Need some help, just got a new f900bt which came installed in my scion, i can't seem to find the parking brake wire (light green), there is no light green wire on the black plug. There is two dark green wires. I know one is for a speaker, i tried the bypass on the other green one, but it didn't work. Does anyone know what position the PB wire is in, or what wires are beside it or above it. Thanks
Posted Jun 13, 2009 · 04:32 UTC#195
On the F90, and the F900 should be effectively the same, the light green parking brake wire is on the connector that plugs into the left-most lower connector of the unit when viewed from the rear, what the AVIC manual refers to as the Power Cord. This is the same connector that the speaker wires feed into. Any chance that your installers just cut the wire off, because they didn't think it was needed? This same connector should have the pink speed sensor wire and the violet-white reverse gear wire.
The medium green and medium green w/black stripe wires are the + and - feeds for the left rear speaker. You don't want to ground these. By contrast, the light green wire for parking is a very pale green.
Posted Jun 14, 2009 · 20:49 UTC#196
I am in the middle of attempting the Hardware Mod. I have found and moved the Yellow Mute wire, but I do not have a light green wire going to the other (Black) connector. I see the two green speaker wires and I have another green wire (same color green as the speaker wires). Does anyone have a picture of the connector so I can figure out which one is the PB wire? Disconnecting the green wire I do have doesn't affect the PB at all! :(
Posted Jun 17, 2009 · 05:31 UTC#197
You should have a long light green wire that would be the PB wire that you would ground.. I grounded it to the black ground wire from my F90BT to the wiring harness adapter.
Check this very detail write up on a similar install with some very clear picture directions. Hope it helps!
http://www.ridgelineownersclub.com/foru ... dio+wiring
Posted Jun 17, 2009 · 10:25 UTC#198
Thanks, I found what I was looking for.
http://i13.photobucket.com/albums/a272/ ... inouts.jpg
My Unit does not have a light green wire going to the connector, so I needed to find a picture of the connector showing the position of the wire or a pin-out diagram.
Thanks for everyone's help
Posted Jun 17, 2009 · 14:28 UTC#199
What is the point of the "read before posting" posts if no one reads or searches them?
The first page of the very first post in this forum.
Postby joegr on Sun Nov 23, 2008 12:54 am
FYI: Connectors and pin-outs
power connector
Mitsumi CCM-G58
http://www.mitsumi.co.jp/Catalog/compo/ ... g57_e.html
1 = Gray = Front Right Speaker +
2 = Violet = Rear Right Speaker +
3 = Gray/Black = Front Right Speaker -
4 = Violet/Black = Rear Right Speaker -
5 = White = Front Left Speaker +
6 = Green = Rear Left Speaker +
7 = White/Black = Front Left Speaker -
8 = Green/Black = Rear Left Speaker -
9 = Light Green = Parking Brake Input
10 = Pink = VSS Input
11 = Violet/White = Reverse Input
12 = Orange/White = Dash Lights Input
13 = Blue = Power Antenna Control Output
14 = Red = Switched Power Input
15 = Black = Ground Input
16 = Yellow = Battery Power Input
Signal connector
JST PADP-24V-1-S
http://www.jst.com/
1 = Yellow/Black = Mute Input
2 = Not Populated = Unknown
3 = Pink = Rear Right Preamp Output +
4 = Not Populated = Unknown
5 = White = Rear Left Preamp Output +
6 = Black = Ground/Sheild for Rear Preamp Outputs
7 = Pink = Front Right Preamp Output +
8 = Not Populated = Safety Bypass (Ground to bypass)
9 = White = Front Left Preamp Output +
10 = Black = Ground/Shield for Front Preamp Outputs
11 = Pink = Right Subwoofer Preamp Output +
12 = Blue/White = Remote Amplifier Power Control Output
13 = White = Left Subwoofer Preamp Output +
14 = Black = Ground/Shield for Subwoofer Outputs
15 = Pink = Right Audio Input +
16 = Black = Ground/Shield for Right Audio Input
17 = White = Left Audio Input +
18 = Black = Ground/Shield for Left Audio Input
19 = Red = Video Input +
20 = Black = Ground/Shield for Video Input
21 = Red = Rear Monitor Video Output +
22 = Black = Ground/Shield for Rear Monitor Video Output
23 = Red = Rear View Camera Video Input +
24 = Black = Ground/Shield for Rear View Video Camera Input
Posted Jun 17, 2009 · 15:18 UTC#200
Can someone Please give the correct step by step instructions for bypassing a F900BT in the United States without draining the battery of a vehicle.
I am reading the forums and there is different information everywhere.
Please help.
Page 8 of 14
