After quite a bit of searching around in the 800_480\ Directory, I came across a good amount of interesting .bmp files. Some of these files are the icons for menus and different sources, some are random, but with this starting list, and with Stephanie's groundbreaking hacks, my intention is to hopefully set up a spot where all members can create their own custom skins for their unit, and share them with others, and make ths unit even more customizable. Here is what I found:
all in the 800_480\ folder (these are not links to images, simply the file names)
The Following are icons:
746_32K_MN_663_32b = Address Book
746_32K_MN_664_32b = P.O.I.'s
746_32K_MN_665_32b = Favorites
746_32K_MN_666_32b = History
746_32K_MN_667_32b = SD Card
746_32K_MN_668_32b = Delete Route
746_32K_MN_669_32b = Some Globe Icon
746_32K_MN_670_32b = Map w/ A Magnifying Glass
746_32K_MN_671_32b = Return Home
746_32K_MN_730_32b = GPS & Time Settings
746_32K_MN_733_32b = Visual
746_32K_MN_736_32b = Route
746_32K_MN_739_32b = Warnings
746_32K_MN_742_32b = Region & Time Settings
746_32K_MN_745_32b = Circular 'R' Icon
746_32K_MN_748_32b = Return Home
746_32K_MN_751_32b = Might be Demo Mode
746_32K_MN_800_32b = MSN Gas Prices
746_32K_MN_803_32b = MSN Movie Times
746_32K_MN_806_32b = MSN Forecast
746_32K_MN_809_32b = MSN Traffic
The Following Are Upper Left icons for whatever menu you're in:
746_32K_MN_663_32b = Upper Left Route
746_32K_MN_663_32b = UL Settings
746_32K_MN_663_32b = UL Address
746_32K_MN_663_32b = UL P.O.I.
746_32K_MN_663_32b = UL Favorites
746_32K_MN_663_32b = UL History
746_32K_MN_663_32b = UL SD Card
746_32K_MN_663_32b = UL Set Home?
746_32K_MN_663_32b = UL Globe Thingy
746_32K_MN_663_32b = UL Map w/ Magnifying Glass
746_32K_MN_663_32b = UL MSN Butterfly
The Following are Miscellanious files that can be use to some members:
746_32K_OM_011_32b = 2D Map Button
746_32K_OM_012_32b = 3D Map Button
746_32K_OM_013_32b = Map Info Button
746_32K_OM_018_32b = Red Dot Button
746_32K_OM_019_32b = Green Dot Button
746_32K_OM_032_32b = View Adjustment Grid
746_32K_OM_033_32b = View Adjust Up
746_32K_OM_034_32b = View Adjust Down
746_32K_OM_035_32b = View Adjust Left
746_32K_OM_036_32b = View Adjust Right
746_32K_OM_043_32b = Previous Screen Button
746_32K_OM_071_32b = Red Crosshair
746_32K_OM_100_32b = Map Compass
746_32K_OM_250_32b = iPod Button (Not iPod Icon)
If you look at any of the .bmp files, there will be a 3 picture column of the same icon.
picture #1 is the icon stationary
picture #2 is the icon when pressed
picture #3 is the icon when grayed out.
Also you'll notice I've only found about half of them...my guess is that the remaining ones are scattered throughout the rest of the flash disk in other directories. So if anybody wants to take a stab at this and try to make a custom skin, or if you'd like to pitch in to help find the rest of the icons and etc, It'd be much appreciated ![]()
