They probably got lazy or just couldn't program past that point.
Nationwide list of Speed traps for Avic Feeds
damn....well what if you saved 300 at a time, can the unit accept multiple fiels of coordinates or 300 is max bottom line
Unfortunately there seems to be no way to split the file in segments when you load it into the app.
Keep playing with it and you might come up with something. I spent all night with mine and Im going to bed now.
Yes Bullshit. When I was playing with Navigate Feeds it did the same thing. You have to use Excel to open the CSV and then split them up. Take the first 300 and save them as file1.csv (or whatever) and then take the next 300 and save them as file2.csv, etc.
I dont think its so bad if you had information regarding the POI location in the CSV file. For instance the Speed Trap one, if they had the location in the description you could make a file for the areas around, for instance, I am in Seattle, so I would have a Seattle.csv, Tacoma.csv, Everett.csv, etc, all with just the info from those areas.
Anyone figure out a better way?
I thought of that method but that list of 20K would require like 80 '300 coordinate' csv files.....after u take the time to make all them do we even know if the F series can hold that many?
What if we load these in the same way as the EU units load speed camera locations instead of using the POI feature?
I don't think there is a limit on that, and they would actually alert you as you approach one, instead of just being a POI.
If you can figure that out, that would be the coolest add-on ever created
Does the US version have that ability? I thought the EU version only did that... But if we could that would be very awesome.
Can someone with the EU model post their data.zip file? That should show us how the speedtraps are implemented in the EU models and hopefully we can just add the scripts to our US models.
In pioneer.ini you will see this:
[speedcam] import_directory="\Storage Card\poi\speedcam"
I'm not sure if it's as simple as adding them to that directory on your SD card and booting up the system, and we don't know what format it expects to have them in, but it's worth trying.
This may be a vestigial line of code from iGo, but from what I've seen, that ini file is pretty specific to the F-Series.
the US update has all the files of the EU update + more, the EU update just has some newer versions of certian files .exe's and newer .dll's some of the .ui files have little tweaks too but like small changes little addons
the pioneer.ini from the EU and US update are the same btw
OK I just got off the phone with Phantom Alert...
Just incase we are unable to put these coordinates directly onto the unit, you can goto www.phantomalert.com, and theres a spot where you can put in your zip code and it'll give you the list of all the traps and coordinates within or near that area.
Not jinxing or doubting anybody that is trying to put them onto the unit, just letting everyone know that if it's not possible, that would be the next best thing.
Does anyone know of a program or website that will change crossroad locations into longitude and latitude coordinates? Goggle Earth does it, but the coordinates in the crosshair are way off and the POI tells you the camera is in a different place.
I know you can cross over addresses, but most red light cameras don't have an address and if you use the closest address, it can put you off by up to a 1000 ft on the navigational map.
Thanks.
Thanks.
would doing that make your destination a coordinate rather than an address?
and would you have to input a coordinate instead of an address as well?
I was going to make my own POI for my city for the Red Light Cameras, but a few in the area only list their location as:
Camera, Bridgeport & San Francisco, Lakewood, WA,
But to put an address there moves the camera 1000ft north which is a different intersection. So if I had coordinates for that intersection, then it would accurate on my AVIC. Avic Feeds require Longitute and Latitude on each location.
I was able to convert the waypoints.csv file into one large .KML file.
I do database conversions and scripting at my work. This was right up my alley ![]()
I haven't tried it yet on my Avic but it does open all 20k in Google earth. The points are all over the world! Plus there appear to be lots of duplicates.
If it's just Avic Feeds that limits it to 300 points then who knows the unit might accept this, who knows. Take a look for yourself. Once I get home I will try this on my avic. Have fun!
Wont work with avic feeds. That file is not set up properly for avic feeds to convert it. In order for the .csv file to be converted with avic feeds it has to have info under the A,B,C,D etc letters at the top which the original file did not. The column to the right with the drop down menus allowing you to pick the corresponding letters is the final step you have to make in order for the conversion to work. That is why I posted my file. I was able to get at least the first 300 to appear on my F90. I could be wrong but I spent hours on this last night and the only way I got the files to appear on the F90 was to do it this way. If you can some way edit the original .csv file in the same way as the file I posted it should work. And if anyone else figures out a different way to make this piece of shit app to work please let me know.
I notice there is another limitation for POI. Inside the "Storage Card/POI" folder, it can not exceed 1.4 MB?
Yea there is a workaround for that at least. Save all of your files to PC instead of USB/SD. You can then drag the whole POI folder to the SD card when done.
Blue if you figure out how to get that huge list of coordinates onto the unit can you make a HOW TO of it? I was so excited when i got that list and now I dont know hw to use it.
Gladly, however it will require complete editing of the original file in the format I described above in order for it to work I believe. That other guy that separated the coordinates might be able to as I dont have the capabilities to edit the file myself.
The phantomalert poi seems to be very repetitive, I see speed trap poi all over the freeway. It isn't very useful at all. You are better off getting a radar detector. I found some incorrect redlight camera poi in my town as well.
VBLUE42 attachment POI is much more cleaner. I split mine for California only. If anyone want the California redlight and speedcamera klm, i'll attach it here.
I know it's probably time consuming as hell but do you think you could separate all by state and post it. If not, what did you use to edit the file?
