1. House numbers:
Use navigatemap_800_480.ui attached. Still needs some cosmetic work but better than nothing.
2. Building Visibility:
Use setting_800_480.ui and setting.ui. Still doesn't work tho.
3. Extra MSN info/settings.
Use msnd_800_480.ui and msnd.ui
You _can_ select what grade of gas you want to see for your prices, see service info and much more.
This is purely work in progress, so cosmetics are nonexistent. Does not save gas grade preference yet. On the main MSN Direct screen I made two hidden buttons visible. Left one turns on debug mode, right takes you to diagnostic screens. Config buttons overwrite stuff but are useable.
4. Speed Cameras:
Use the same setting.ui files. I didn't size/position them yet, but they are there. When you activate speed camera warnings you get a legal notice. Obviously you need speed camera files imported.
5. Secondary data folder.
In sys.txt you can add a line:
secondary_root="iGO"
Now, on your SD card create "iGO" folder. Inside create "content" folder. You can put same data as what is in iGO's content folder. I'm not sure yet which ones override one another, but adding the detailed terrain (.DEM) file (one too large to fit on AVIC's flash disk) caused it to draw terrain on the 2D map much more detailed. Too much load for the CPU though sop I'll take it out, I think. You could, theoretically, add voices, POIs etc. there without having to go into testmode and copy to the internal drive...
6. POI icons and visibility.
Find user data folder on your AVIC (it's not in APL2/IGO... it should be somewhere on the top level. Navigate to iGO and insude there will be "save" folder. This is where iGO saves current working settings, and as I understand what is in there takes precedence over everything else.
Interesting file there is POI_VISIBILITIES.TXT
It seems to be structured like tghis:
Primary_Category [optional]] | icon name | visibility.
I.e.:
Contacts|contacts|0 <- Contacts category. Use contacts icon. Not shown
FinanceBankBANK OF AMERICA|poi77|0 <- Finance category, Bank subcategory, icon named poi77, not shown on map.
Petrol_StationPILOT TRAVEL CTR||500 <- This gas station uses default icon for its category.
This should be helpful for two reasons:
a) If you go through all POI categories/subcategories and assign them any random icon, the file will be populated. Then you can use a branding.zip file (like the one I posted before) to assign icons on a computer before taking it back to AVIC.
I have a feeling that 500 that it insists on inserting for all gas station is what causes them to always show up on the map. I've replaced them with 0 and will see tomorrow if it makes them go away.
