Progress Report
By BorisM · Sep 10, 2008in Hacks/Mods💬 361 posts👁️ 65,220 views
Page 2 of 15
Posted Sep 18, 2008 · 02:08 UTC#26
I usually have all files extracted to a working directory, then I select them all (from the top level), right-click and select WInRAR's "Add to Archive" option.
Then make sure you have selected to preserve paths and use ZIP archiving.
Posted Sep 18, 2008 · 02:22 UTC#27
Here's the latest version of my scripts:
1. Duplicate scripts removed.
2. Needed scripts cleaned up a bit for smakker size
3. Software bypass
4. skycrave's blue box fix
5. POI address search (still needs cosmetic work)
6. Speed cameras
7. House numbers
8. Visible MSN Directo debug buttons
9. Route settings allow turning "snap to road" on and off
10. Route settings allow changing vehicle type (care, pedestrian, truck, taxi, bus, bicycle, emergency) - 700-90 models only right now.
11. Decent Branding file
TODO:
1. better detour interface
2. Cosmetics for POI address search
3. Route simulation speed control
4. Home/Favorites button on main screen...
Posted Sep 18, 2008 · 06:31 UTC#28
borism great job, i'm gonna throw it on my headunit tomorrow :) see how i like it
Posted Sep 18, 2008 · 14:13 UTC#29
Will the software bypass be effected by the hardware bypass already done?
Posted Sep 18, 2008 · 16:15 UTC#30
Enjoy!
Note: if you waqnt to clean up your DATA.ZIP, you could try deleting all of UI files that are not in my archive... There were quite a few duplicate files in the original, particularly in COMMON direcotry it duplicated all files from COMMON\UI...
cigga24 --- no, it should not have any effect on the hardware bypass at all.
Posted Sep 18, 2008 · 23:37 UTC#31
BorisM,
I dont know if its my unit or not, but I was using the old scripts you had and I could go on the map and move the cursor to a place on the map and set up a new camera, but the new scripts, when I move the cursor, it removes the button that lets me add a camera to the intersection. Did you make some changes on how that interacts?
Thanks.
Posted Sep 19, 2008 · 00:25 UTC#32
Strange... It does work for me. I'll double-check when I get to the car, but it was working yesterday...
Posted Sep 19, 2008 · 17:27 UTC#33
Still working... This Speedcam button ius defined in PLACE.UI and I didn't even change it in the latest scripts...
Posted Sep 20, 2008 · 07:27 UTC#34
Mine started working today, so it had to be something in the interpretation not in the script. Everything works great now.
Posted Sep 20, 2008 · 15:38 UTC#35
Good to hear!
Posted Sep 21, 2008 · 02:24 UTC#36
I just installed your latest scripts. So far I like it, although it could use some cosmetic fixes. I didn't quite understand the detour screen. I figured out that it presents saved searches, but the text that tells you to select distances for something was not readable.
By your above statement are you saying that all files that were not part of your scripts.zip file can be deleted (i.e. the scripts.zip could be renamed data.zip and could completely replace the data.zip file?). I just used your scripts to update a copy of my data.zip. I see what you mean by the duplicate files, there are quite a few of them.
Posted Sep 21, 2008 · 03:28 UTC#37
Yeah, cosmetics aren't my strongest side... :(
The detour screen... So far I just uncommented code that hides it, so if you set something to avoid from the Itinerary screen, you can fix it there.
On a real iGO skin this button would do much more. I am trying to study a couple of the more advanced skins to see how difficult it would be to rip out advanced detour management.
On a proper skin you can do things like set certain streets to be avoided on certain days/times (i.e. don't use that highway to downtown during rush hour, but use it if it is empty other times)...
Re: cleanup. No, you don't want to use my archive _instead_ of the original. You still need sounds and bitmaps I removed to comply with forum's file size limits. However, AFAIK any UI file that is not in my archive is a duplicate and probably not used... At least even after a few longer trips I haven't had any problems without them.
Posted Sep 22, 2008 · 18:26 UTC#39
BorisM these are really impressive skins, are you trying to implement these?
The iGo8 skins are nice, i like how the trip info is much larger and stretched the length of the screen.
Posted Sep 22, 2008 · 18:36 UTC#40
For those who want to explore some of the more advanced skins for iGO here are links to two of реу more popular ones:
Gurjon: http://sites.google.com/site/gurjon/Home
diMka: http://www.igo8mods.com/dimka.htm
On the second link, it provides audio files for cameras. Have you had a chance to work with these yet? Any suggestions?
Posted Sep 22, 2008 · 19:19 UTC#41
Yes, I'm trying to pull some things out of them. Unfortunately, since NavNGo isn't exactly forthcoming with information about the scripting language, it is a slow process...
Speedcamera speech files require a special script. I will have to see how difficult it is to add it in...
Posted Sep 24, 2008 · 06:54 UTC#42
it's gone I don't remember if it was gone after I install this data.zip file
it's still there in 3d.I found this pretty common problem but any solution yet?
BTW you guys rock this forum convinced me to by f over keenwood..
Posted Oct 01, 2008 · 02:13 UTC#43
Added more enhancements:
1. Cosmetics are fine now on the POI screen for Address search.
2. Moved house numbers to the Current Street display (combined_textmodel rocks ;) )
3. Added Turn Restriction indicator. If you are passing by a one-way street, No (left/right) Turn sign will appear on screen.
4. Fixed up route simulation. Instead of Fly Over, button now says "Simulate". When you click, it will ask if you want to do a Fly Over or Simulation. In Simulation mode, you get voice announcements, camera warnings, etc. Also, on screen, next to Stop Simulation buttons, you now get Slower/Faster buttons, because Simulate can be rather slow (it drives speed limit :) )
TODO:
1. Figure out detour screen. Still can't get it to show anything useful
2. Better hiding of simulation speed controls. For now, they get hidden only when you stop simulation with the green Stop button.
INSTALLATION:
Either add files to your DATA.ZIP, or copy the entire ui_pioneer folder into your iGO directory. Whatever files are present there override ones inside DATA.ZIP.
Posted Oct 10, 2008 · 01:37 UTC#44
BorisM i cant find this pioneer folder on my avic. I go to myflash/apl2/igo but there are no other folders. I enabled hidden folders also under the view menu.
when i downloaded and unrar your scripts i get two folders; common and 800_480. Should i just drop these two folders into igo folder?
Posted Oct 10, 2008 · 03:44 UTC#45
Make a folder named ui_pioneer, extract the archive there (preserving folders in the archive) and copy the whole thing to iGO directory.
Or, copy files into same locations in your DATA.ZIP
Posted Oct 10, 2008 · 11:36 UTC#46
I'm using a Mac and for some reason it didnt create the folder like winzip does. thanks.
Posted Oct 10, 2008 · 14:14 UTC#47
TODO:
INSTALLATION:
Boris, could you point out/post the changes you made to your navigatemap_800_480.ui file. I like to fully understand what changes people have made to their files before I implement those changes to mine. Looking through the navigatemap_800_480.ui in your zip file, I can see several comments added but I'm not sure I understand what each does.
Posted Oct 10, 2008 · 14:23 UTC#48
also the address #s do they always show up or only when in route on destination road?
Posted Oct 10, 2008 · 15:04 UTC#49
House numbers show if the map has them, regardless of routing (since it always shows the street you are on, might as well show numbers...).
I've tried to comment changes I made to the file, but can't be 100% sure right now :)
I would simply run a file-compare against the original. That's what I do when something breaks :)
Posted Oct 10, 2008 · 15:10 UTC#50
can you take a picture of what the address#s look like and post?
Sorry but in the latest scripts is the speedcam setting enabled?
Page 2 of 15
