Color Schemes
By BorisM · Sep 27, 2008in Hacks/Mods💬 99 posts👁️ 33,705 views
Page 3 of 4
Posted Jan 27, 2009 · 21:35 UTC#51
That's weird... I'му never seen it. Does it work with night schemes?
Posted Jan 27, 2009 · 21:47 UTC#52
Night schemes all are 'dark' to reflect a night view, but again all look the same no matter which scheme you select. Need help!!!
Posted Jan 27, 2009 · 22:04 UTC#53
Very strange... I would suggest deleting everything form iGO's SAVE folder except for favorites.dat file and see if you can reselect schemes...
Posted Jan 28, 2009 · 03:38 UTC#54
OK, possible problem as my IGO directory contains no SAVE folder (and of course this means no favorites.dat file).
I can create a 'save' folder, but where do I get a favorites.dat file?
Posted Jan 28, 2009 · 14:38 UTC#55
It's not in iGO prograqm directory.
MJy Flash Disk\USER\UserData\iGo\save
Posted Jan 28, 2009 · 17:25 UTC#56
Were are you graphics guys getting the carbon fiber looking backgrounds for these graphics? I'm an advanced Photoshop guy and I love that look but I can't find the images or tutorials on making them.
Anyone?
Tom (the knob guy)
Posted Jan 29, 2009 · 18:10 UTC#57
That worked Boris - thanks for the help. Odd thing was there was no favorits.dat file in the Save folder, but I deleted all the others and rebooted and the screens seem ok now..
Posted Jan 29, 2009 · 19:01 UTC#58
favorites would exist only if you have actually defined any favorites on the AVIC. If you didn't, then don't worry about it.
Posted Feb 13, 2009 · 20:55 UTC#59
to make the modded real-view schemes work you need to add the following folders/files to your flash drive:
(download and unzip gfx.zip, you will have a gfx folder with 2 sub-folders in it called day & night)
add the gfx folder to:
my flash disk/apl2/igo
so it would look like this:
my flash disk/apl2/igo/gfx/day
my flash disk/apl2/igo/gfx/night
then the real view schemes modded by boris will work
gfx.zip
Posted Feb 15, 2009 · 16:32 UTC#60
The themes already worked and we already have gfx folder. You placed this outside of the current gfx folder? Do you now have stars, a spaceship, a sun and moon?
Posted Feb 15, 2009 · 18:40 UTC#61
- and clouds too, depending on the theme. :)
I didn't already have a gfx folder, so i only am using the one i described, sorry if I wasn't clear or made things confusing!
Posted Feb 15, 2009 · 20:28 UTC#62
Your using the regular pioneer gps or leetlauncher when using the schemes and seeing the sky's? I've gotten the sky's to show up in leetlaucher but cant get them to work in pioneer igo.
Posted Feb 15, 2009 · 23:38 UTC#63
I just went out to my car and put the gfx folder where he said and still no sky's. He definately must be using the leetlauncher igo and not the pioneer igo.
Posted Feb 16, 2009 · 15:51 UTC#64
sky with clouds or night with stars doesnt work only if u have R3 igo.
we have R1
Posted Feb 19, 2009 · 05:23 UTC#65
Anybody wanna post which they are using? I find a lot of them to be too hard to see street names, or hard on the eye's... The Realview nights are a good example, way too yellow.
Posted Feb 19, 2009 · 09:22 UTC#66
I have a Pontiac Grand Prix and all of my interior lighting is red. When I downloaded these themes I came across Monopoly Nite and love the setup, but all of the roads are blue. Can anyone help me in figuring out what vales must be changed in the file to maintain black ground but change all of the road colors to red? Thanks in advance for any help.
IF YOU FIGURE THIS OUT POST IT UP OR PM ME BECAUSE I WANT RED TOO. also ill turn the cap locks off now. thanks.
Posted Mar 05, 2009 · 21:34 UTC#67
Can anyone please explain how to act if I want the stock sky BG in the realview V6 scheme?
For us poor avic 8.0 users have no clouds, I find the sky much to bright.
I like the (stock) blue one a lot better
Posted Mar 05, 2009 · 21:57 UTC#68
I would guess... in the color.ini file for the scheme there's a line:
3d_sky = 0, 255,255,255
I suppose it does the brightest setting for the sky bitmap, setting scheme to full white. Change it to something more subdued. I.e. here's one from Pioneer Blue Day:
3d_sky = 0,100,174,231
Posted Mar 08, 2009 · 10:14 UTC#69
yes that's it.
is there some kind of guidance on what is what exactly?
for e.g. I can't seem to find what cointains the colors for highways in the reality view stormy.
did some comparing with other schemes, but every string I tried ws not the one.
Posted Mar 08, 2009 · 21:00 UTC#70
yes that's it.
Not much guidance, other than comments inside schemes themselves. You could try searching for iGO Scheme Editor, but it is very very beta...
Posted Mar 16, 2009 · 02:35 UTC#72
Ok sorry i am a noob but whith the schemes do i need to copy cursor_places.spr from cdommon to common/night directory in DATA.ZIP and if so can i use the the keyboard in testmode to copy it. If so is it is Alt+C correct someone please help i dont wanna do this wrong Thank you in advance.. Thank YOu..
Sorry Ctrl+C then Ctrl+V
Posted Mar 16, 2009 · 06:07 UTC#73
No, since it is inside a ZIP archive, and file explorer in AVIC does not handle those, you need to do it on a PC...
Posted Mar 16, 2009 · 17:52 UTC#74
there are a total of 4 zip files with multiple zip files and .png files. Do you unzip the 4 original files and add each zip within those files 1 by 1 or just add the 4 zip files to the directory. Please help. Thank you
Posted Mar 16, 2009 · 19:19 UTC#75
Thank you Boris so basically copy that file onto my sd card copy that file i need into the other folder on my computer then stick that into the folder on the avic in testmode correct.. Kevin
Page 3 of 4
