So apparently I'm struggling here. I have made change after change but am probably doing something fundamentally wrong.
I took one of the theme .zip files and copied it to something else... MyTheme.zip. I then modified the colors in the file to be basically the same thing that you see in the Pioneer Blue Day theme but with a light tan/kahki ground background that is something similar to the Xersus Summer theme. Change after change, same results... nada.
Once I change the color.ini and color3d.ini files I put them back into the zip file which also contains a "content.nng" file and "dayheightcolormap.bmp".
So clearly I'm doing something wrong. Can someone help point me in the right direction?
Also, here is some reference material...
this site will allow you to put in RGB values and see what the color is. This is helpful when trying to figure out what color the .ini files are referencing. http://webdeveloper.earthweb.com/reposi ... 1/hex.html
this site will allow you to look at a color and see the value (basically the opposite of what is above). http://web.njit.edu/~kevin/rgb.txt.html
Thanks in advance for your help. This is starting to drive me nuts.
