Well, I originally came here to simply learn how to do the bypass on my F900....one thing led to another and here I am a week later having performed a number of mods that make this unit dramatically more user-friendly than it was when I initially got it. Since I spent an inordinate amount of time wading through the information here (I've literally read just about every post in every thread at least once and several of them several times) to ferret out useful information, I thought it would be helpful to have a thread that shows what I did and then breaks down each mod. Some of these were made by me; some were lifted wholesale from others here; but none of it would've been possible without this community of very well-informed individuals; you should be very proud of what you have here. Special thanks to Boris, Stephanie, Keeper, and Vorian.
Alright, here's what I did:
1. Clock/Street Number Info - Increased its size. Also, pressing the clock displays the street numbers adjacent to your current GPS location. Pressing the street numbers makes them go away.
2. Compass - This is a simple man's detour. When no route is active, it's just a compass. When a route is active, pressing the Compass brings you directly to the edit itinerary screen where you can quickly avoid/detour-around route segments.
3. Terminate Route / POI Select Button - When no route is active, this button is the POI Icon; pressing it brings you directly to the keyboard for POI searches near your GPS location (this was tougher than I thought it was going to be) for on-the-fly (assuming you have the bypass) quick navigation. When a route is selected, this button is Red; pressing it terminates the route.
4. Navigation Mute / Address Select Button - When no route is selected, this button is a House Icon; pressing it brings you directly to the address select screen for on-the-fly (assuming you have the bypass) quick navigation. When a route is selected, pressing the button mutes the navigation commands (nothing else is muted); pressing it again unmutes.
5. Satellite Signal Strength Icon - The color of the icon indicates its signal strength (green = high accuracy 3d fix; Yellow = low accuracy 2d fix; Red X = no fix; Red: GPS antenna problem). Pressing the icon brings you to the GPS Info screen.
6. Speedo/Altimeter/Route Info - The map scale has been removed completely (what a PITA), and the function of the route info box (bottom left) has been changed. When no route is selected, the Route Info box is gone and in its stead is a simple altimeter (showing altitude in feet, not miles) and speedometer (and when a speed limit information is detected, that's also displayed). When a route is selected, a modified and much more legible version of the Route Info box appears.
That's it, and frankly, I think I'm nearly finished with my mods.
MY DATA ZIP FILE IS HERE. Of course, I do not guaranty the effectiveness of this file and by downloading the same, you are agreeing to use it at your own risk and to hold me harmless from any issues it may cause with your unit.
Code, bmps, and specific information to the individual hacks follow in the following posts.
Here are pictures:
No Route Active:
Route Active:
Thanks all!
