i've been messing with this and can't get seem to get it right...
i have a couple of criteria i'm trying to meet.
1. to not cover up/overlap iPod album cover art on the bottom of the x=720 axis
2. regular sized clock
3. replace GPS sat with Voice Mute Mod
; *** Voice guidance mute mod by Gert-Jan ***
; *** End Voice guidance mute mod ***
any help would be greatly appreciated
HA! Boy are you in the wrong thread! I don't have an iPod hooked up, so my mods don't account for criteria 1; one of the features I DID incorporate was a bigger clock, so there goes criteria 2; and I don't have the voice-mute button in my hack, so there goes criteria 3.
Having said that, I'll try to help. As I understand it, you want the following to appear in the 720 column (from top to bottom) while leaving room for the iPod album cover at the bottom:
Clock
Compass
Navigation Mute
Map Confirmation (nothing you can really do with this one)
2D/3D Button
Green/Red (POI Search/Cancel Route)
Although I don't have an iPod, I know from seeing units with the Cover Art up that this is going to be next to impossible. That is, you probably won't be able to squish the buttons close enough together to leave enough room for all of them and the cover art. This is due in large part to the fact that so far as I know the Map Confirmation button is unmovable, so you only have the 2 buttons below it to "play with" to make more space. If someone comes up with a way to move the Map Confirmation button (http://www.avic411.com/forum/viewtopic.php?t=19886), the analysis may change, but until that time, your options are somewhat limited.
Here are 2 proposed solutions.
1. Remove the Clock and move the street number toggle to a hidden button below the current location arrow (which is how Keeper has his originally set up). Then using the space freed by the removal of the Clock, set the buttons up in the following order:
Compass
Navigation Mute
2D/3D Button
2. Keep the Clock, but move the Compass (or something else) over to the left side (just above the altimeter when no route is active and just above the route info box when a route is active). Then using the space freed by the relocation of the Compass, set the buttons up in the following order:
Clock
Navigation Mute
2D/3D Button
Let me know which you want to try (or if you have your own proposed solution), and I'll work through the code with you.
