Euro Spec F900BT - Upgrade to Voice Control?
By marmski · Sep 28, 2008in Hacks/Mods💬 84 posts👁️ 22,033 views
Page 3 of 4
Posted Oct 01, 2008 · 20:56 UTC#51
ahaaaaa
in navigatemap_800_480.ui I find this :
;corner picture
the 'Saynextcommand' is our EU function ... What is the US function ?
Posted Oct 01, 2008 · 21:06 UTC#52
Same thing. SAYNEXTCOMMAND is iGO's internal function that says what your next turn should be. Has nothing to do with voice control of the unit, though.
Posted Oct 08, 2008 · 20:24 UTC#53
Have we reached the end on this one :(
Posted Oct 10, 2008 · 18:45 UTC#54
Bump - any ideas? i would love to get this working... i feel cheated in a way because i thought it could do it as standard!
Posted Oct 30, 2008 · 19:03 UTC#55
There's still no solution for it??
It should be possbile to unlock these features.
We european F-series drivers.... we want it also... :(
Posted Oct 31, 2008 · 13:18 UTC#56
it would appear not.
im really annoyed that we cant have it, no matter how bad it may be. :(
Posted Nov 10, 2008 · 16:15 UTC#57
Helloo i wanted to open this topic back up as i really want voice control on my EU F900BT any ideas, i noticed when installing the 1.9 update it does install voicebox software but i cant see any way of acticvating it.
Anyone?
UPDATE - I was fiddling around in test mode the other day and found the app which appears to control voice control the thing is i spoke and it could hear me because it done some commands but didnt actually recognise them well it appearted so anyway could anyone tell me the commands that are the US models so i could try one of two.
Thanks.
Posted Dec 27, 2008 · 14:42 UTC#58
Are there any updates on this one?
Reading the past post i guess the VR support comes together with putting the unit into "Enlgish (US)" language.
Has anyone managed to do this on non-US version so far?
Thanks guys..
Posted Jan 10, 2009 · 00:06 UTC#59
any progress here? i own a eu avic-f700bt. Booted into test mode, but cant figgure out the script. Anny one else?
Posted Mar 24, 2009 · 02:10 UTC#60
There seems to be loads of threads on this topic, I bet we (us Europeans) are annoying the hell out of you guys in the US with weekly posts about if and how we can get voice recognition :)
I have the F900BT sat in it's box, about to return it as I wanted the voice recognition for easy navigation of my iPod/iPhone library. Didn't think to check the UK website for the detailed specs, the US vids on YouTube sold it to me!! Was quite impressed with the "non-voice" iPod navigation though as most I've used have been really slow, but it's pretty fast on this unit. Thinking about getting the US F500BT now and just adding it to my existing system, as there will be no DVD region issues, no radio issues (as it uses the original stereo....doesn't it?) so will hopefully just be a case of updating the maps to the UK versions.
Noticed there hasn't been a post in this thread for a few months, don't suppose that's becasue there's a miracle "fix" to get voice rec that I don't know about? :roll:
If not......I'll pay the first person who can work it out a million pounds!!!! I mean dollars.....ok, I mean nothing!! But I'll be the happiest boy in the world and you'll be a god to so many :lol:
Posted Mar 24, 2009 · 07:45 UTC#61
Just for the record:
I changed my F900BT for a Kenwood DNX-8220BT and lived happily ever after...
OK there's still no voice recognition support for iPOD/iPHONE (which I don't have anyway, Android all the way :twisted: ), but at least I have voice dial support.
Posted Apr 21, 2009 · 16:03 UTC#62
I've bought the 900BT also thinking on the VC and got very disappointed when the VC didn't work and after reading several threads on this forum.
Have anyone tried to install some voice recognition software for Win CE after hacking the avic-f units to see if it's usefull? If it would be usefull I think the easiest thing to do after that would be assigning the button so it would launch the voice recognition software upon any button press.
Posted Apr 24, 2009 · 18:07 UTC#63
Just an update on this. I have managed to get my EU model (UK) into US mode. I was basically having problems with my Bluetooth after doing a mod to improve the iGo nav screen.
Anyway, I found a backup of the entire flash drive from an F90bt (a US only model) on this forum. Backed up my entire flash drive, then deleted everything and the replaced with the US files. I had to use the hacked version of ezrider.exe and the world wide licence as the US maps wouldn't work otherwise.
The unit works ok but no voice commands yet. One thing I have noticed is that in test mode, under system properties and device name it says F700bt, even though it's an F900bt. Can anyone tell me what the US version says? Just curious.
I'm going to keep at it as I have a few ideas.
Posted Apr 24, 2009 · 19:06 UTC#64
They all say that., because they run exactly the same software. Actual device model is determined from some hardware switches.
Posted Apr 24, 2009 · 20:09 UTC#65
Thanks for that Boris. I assume you mean the Windows CE software?
I'd also like to know how the US volume button works. If you're in iPod mode for instance, do you push the button upwards to activate voice commands or inwards?
If I push mine upwards noting happens, push it in briefly in nothing happens, push it in and hold and it mutes.
In Nav mode pusing up zooms in and pusing in repeats last route command, is the US one the same?
I know this is probably pointless as it's likely there is a hardware difference, but I don't mind trying. Also, one final thing. In the F90BT (US) flash drive in APL2, there is only 2 folders.....1 iGo, 1 VBT. There isn't supposed to be another one is there?
Thanks!!
Posted Apr 24, 2009 · 20:14 UTC#66
Thanks!!
Yes, this is what CE reports. But all units run exactly the same navigation and AV software, too...
To activate voice control on US units you push the button in.
Hardware differences that were found so far are limited to different radio tuners and some switrches on the PCB that control country, DVD region settings, etc...
Posted Apr 24, 2009 · 23:12 UTC#67
Making some progress....I think!
I've got the Win32XMLApp.exe (in APL2/VBT) working and it recognises my voice commands. If I try and run VBTEngine.exe from Test Mode it just crashes the system.
Here's the app:
VoiceBox_CallMum.JPG[/attachment]
It recongnised the command!! Here's another one, I said "Cancel that" and it picked up what I said :o
I'm guessing if I could launch VBTEngine.exe while the system is up and running, it might work. Not sure how we might get the volume button to do that, but how about Boris's suggestion of putting a "soft" button on the nav screen or the ipod screen to launch it. I've not looked into modding stuff like that yet, assuming it's all in data.zip?
Judging from what I've seen I don't think it should be too difficult? Can anyone help?
Posted Apr 27, 2009 · 22:24 UTC#68
Is there any update on the Voice Command for the UK model yet??? I only bought the unit as i thought it had VC, when i found it didnt have it i was very dissapointed. Why did pioneer leave it out for eveyone but the US. Im sorry but it just takes the piss. :cry:
P.S well done guys for all the hard work so far.
Posted Apr 28, 2009 · 00:49 UTC#69
Hi Bego,
you're not alone, I did the exact same thing. Was sold by the Voce rec and was gutted when I realised we didn't get it in the UK. I'm guessing the reason they left it out has something to do with the fact that Voice recognition doesn't work as well for us in the UK as our accents vary massively. Either that or the developers can't be bothered to develop it for such a small market (compared to the US at least). Same thing with iPhone voice apps, it's all geared towards the US market.
In the UK we probably have 10 million people with close to "standard english" (so news reader like) accents. In the US there are probably ten times that! I might be wrong but I can understand all Americans no matter where they're from, I can't say the same for the UK. I've lost count of the times when I've had to just nod and smile at a Glaswegian or someone with a think Irish accent.....I think you get my point :wink:
However, I wish they'd have just added it in anyway as I'd rather it worked badly than not at all. Perhaps the new version 3 software will bring us VR....but I won't hold my breath.
Just so you know though, I'm over it now though and happy with the unit. The start up time isn't an issue for me and is easily compensated by the fact that you can totally mod it, definitely think this is better than the Kenwoods.
Sorry for rambling!! :D
Posted Apr 28, 2009 · 11:46 UTC#70
Klanbo, I noticed u got it working in what looks to be test mode, did u not pursue this or have u given up? Thanks for the reply btw I suppose it makes sense with what u said, still think they shouldn't have taken it out though it will work for most of us or at least made it an option. What's more is I think on one of pioneers newer models they have VR for the UK and the screen is tiltable!!! Anyway I work for an IT company and am good friends with some of the programmers, I have asked if they can have a look to see if they can get it to work. Can anyone tell me what I will need to provide them? I'm guessing the uk data and the US data and the windows platform maybe?
Posted Apr 28, 2009 · 13:44 UTC#71
Not sure where you folks are on this. But if you want a copy of the F700 2.0 "Myflashdisk" to compare, pm me your email address and I can set you up to download it. Full size is 1.6Gb, but You can / could lower that by not downloading the maps.
Posted Apr 28, 2009 · 17:26 UTC#72
Please excuse my ignorance does the f700 have voice control? and is it UK spec?
Posted Apr 28, 2009 · 17:52 UTC#73
Just a thought, has anyone tried downloading the american software and just swapping the maps over so the maps are UK?
Posted Apr 29, 2009 · 03:03 UTC#74
I believe all the F series US models have voice control. The F700 comes in UK and US spec, as does the F500 and the F900. The US get a Premier model too, the F90.
Anyway, yes I have tried putting the US software on the UK model, still no voice control with both US maps and UK maps, no joy though. As much as I'd love this to work I don't really have the time to spend on it, but more importantly I don't have the expertise!! :?
I was hoping that a "soft" button could be placed on the screen to activate the voice rec software, but from what I've read it's harder than it sounds. The problem seems to be calling an executable file, in this case the VBTEngine.exe from the Pioneer software. I think if it could somehow be launched at startup along with the other .EXE's (like MainMenu, Ezrider, AV, Navi, Video, etc) then it might be possible to call VBTEngine.exe using the "EXEC" function.....but that's beyond me at the moment.
It's a bit like trying to add a button to Outlook that will open iTunes, I wouldn't even know where to start but I bet someone does.
Boris and Stephanie appear to be good at this sort of thing, how are your bribery skills? :lol:
Posted Apr 29, 2009 · 15:33 UTC#75
sorry to rain on your parade but iv noticed a big problem, in our settings menu we have nothing about VR ipod cataloguing so this to me suggests there is something else it does maybe another task or exe.
and i tried the whole US firmware on EU unit it works but no closer to VR.
Page 3 of 4
