East Coast Disc FTP Information Contained in this post.
By jlong1987 · Oct 04, 2008in General💬 234 posts👁️ 51,283 views
Page 2 of 10
Posted Oct 04, 2008 · 13:38 UTC#26
Not sure what is up with the small iso ... I recommend he ZIP ... it definitely works .... my D3 was just updated. Below is the second screen you get after inserting the disc ... THe first Screen has a message saying disc is being checked .. I wasn't quick enough to get a picture. Then this screen comes up for 30 seconds or so during the update.
BIG THANKS to all those involved in making the EAST disk available!
Posted Oct 04, 2008 · 14:10 UTC#27
Do not download the ISO. I stopped it when I was sending it to jlong because it was so big. Download the zip file, then unpack and burn.
The correct file size of the ISO is 7.6 GB
Jlong, delete the ISO file that I started to send at the first...I didn't have the rights on your server to do so.
Posted Oct 04, 2008 · 14:15 UTC#28
downloading zip right now with great speeds...thanks so much!
Posted Oct 04, 2008 · 14:17 UTC#29
what do you consider great speeds?? i have a fast connection and im downloading slow around 50kb/s
Posted Oct 04, 2008 · 14:22 UTC#30
You don't have a fast connection then. I have a 6MB account and I'm downloading at 475KB/sec.
Also, I already downloaded the ISO and it definately is bad. I burned it to a DL DVD and the Avic-N1 wouldn't even read it. When you open it in MagicISO it looks like it is 7.6MB but when you look at it with file explorer it is 2.9MB. You should definately delete that one before it spreads around.
I'm now downloading the ZIP which looks like it is the correct size.
Thanks again for hosting with your FTP
Posted Oct 04, 2008 · 14:22 UTC#31
i'm getting 200 kb/s constant right now...that's the max i can get usually on my connection
Posted Oct 04, 2008 · 14:24 UTC#32
i usually get download around 300 kb/s but for some reason download through filezilla i cant pass the 50s kb/s
Posted Oct 04, 2008 · 14:25 UTC#33
Maybe your ISP is capping you. Why are you using Filezilla? Just go to his FTP and d/l with IE.
Posted Oct 04, 2008 · 14:35 UTC#34
Is there an ISO file included inside the zipped folder? I will be burning the image with DVD Decrypter. Thank You for the East Disk
Posted Oct 04, 2008 · 14:37 UTC#35
You might have connection issue. I'm currently downloading at 740kb/s!
Thanks for the file!
Posted Oct 04, 2008 · 14:41 UTC#36
No, you can either choose to download the ISO file or the ZIP file from his FTP. The ISO file is bad but hasn't been removed from the server yet. Just make sure you download the ZIP file and you will have no problems.
Posted Oct 04, 2008 · 14:44 UTC#37
Yeah I know that I downloaded the ISO file while I was sleeping last night only to wake up to find out it was bad. Downloading the Zip now. What I meant with that question was, is once I unzip the zipped file will there be an iso file to click on so that DVD Decrypter can burn the image?
Posted Oct 04, 2008 · 14:48 UTC#38
Yes (As long as DVD Decrypter burns ISO Images)
Posted Oct 04, 2008 · 14:50 UTC#39
Thanks boss thats all I needed to know. I am downloading at around 190kbs. I have six hours to go :shock:
Posted Oct 04, 2008 · 14:55 UTC#40
thank you so much!! at 750kb ! quite quick
Posted Oct 04, 2008 · 14:57 UTC#41
I had to cap the max connection for that user group to 100 MB/s a second because my money making site is up there and I was having trouble with connection speeds for that. Checked my log files and the average download speed is right about 525 KB/s. I have had 498 completed request with 8 failed request and 219 active transfers.
-- I am deleting the ISO -- Please download the Zip
Posted Oct 04, 2008 · 15:08 UTC#42
decided to go on my campus to get better download speeds...now dl'ing at 850 kb/s :lol: now i just have to kill an hour on campus...
Posted Oct 04, 2008 · 15:15 UTC#43
Yea Im gettin about 526KB/sec as we speak. Not bad
Posted Oct 04, 2008 · 16:14 UTC#44
549 completed downloads in a little over 15 hours. If my math is correct that is just about 37 successful downloads an hour. which isn't to shabby
Posted Oct 04, 2008 · 16:17 UTC#45
After the ZIP file is done, all I have to do is unzip it and burn?
Posted Oct 04, 2008 · 16:17 UTC#46
Thanks to Rotun I now have the West coast disc up on my FTP in .rar format. To clear up any questions you will need to download the entire 2008 West folder and then use your favorite program to create an ISO from the .RARs. the link is
ftp://vwinvoices.com/vwinvoices.com/upl ... c_08_west/
the username: guest_uploads
the password: guest1234
good luck
Posted Oct 04, 2008 · 16:27 UTC#47
good luck
Select all and extract, once extracted it will already be an .iso, read the .txt for password to extract.
Posted Oct 04, 2008 · 16:43 UTC#48
Also, thanks to allsounds ( ibelieve it was him) for putting the 2008 on rapidshare as this is where I obtained it.
Posted Oct 04, 2008 · 18:22 UTC#49
almost done dl'ing...getting pumped to burn and try this baby out!
Posted Oct 04, 2008 · 18:23 UTC#50
everytime i download from the server it comes out .part is this ok? and does it still need to be burnt on a dl dvd
Page 2 of 10
