East Coast Disc FTP Information Contained in this post.
By jlong1987 · Oct 04, 2008in General💬 234 posts👁️ 51,283 views
Page 7 of 10
Posted Oct 07, 2008 · 22:21 UTC#151
Is there anyone that has successfully burned a copy of the new disk that could sell me a copy? I need the updated East disk for my D3, but I do not have a dual layer burner.
Posted Oct 08, 2008 · 10:09 UTC#152
Hey Morfious, is that the "ACTUAL" (Not the N5 disk) CNDV-80MT disk? You wouldn't happen to have the west one available, would you?
the east disc is it the actual upgrade or is it the disc for the n5???
The is the same image that was downloaded from the ftp site. It is the actual 80MT disk NOT the N5 disc. I do not have the west disc or else I would put that up as well.
As for burning you have to use the "burn image" tool in your burning program.
Update directions for dummies (Using my nzb file)
I'll assume you already have premium newsgroup access and a news program such as Unison or Newzleecher.
Unrar the multiple files and you will be left with a file CNDV-80MT East.iso this file should be 7.6 GB
Open up your burning program (Nero, alcohol 120% toast ) and pick burn disc from image ( or whatever it happens to be called in your particular program).
Click the big burn button and wait 30-40 minutes. I picked 2x speed to ensure a good burn. You must have a DL burner and media.
Take the disc out to the D3 (along with the disk you made that has your custom screens on it). Turn on the D3, eject your old disc and put in the new one. It will automatically see the new map info and start updating. Wait 3 minutes and it will be done. Eject the disk and restore your custom screens and you are finished. I had no problems with this at all.
Posted Oct 08, 2008 · 15:47 UTC#153
Actual CNDV-80MT disc will be available later today on my servers.
Posted Oct 08, 2008 · 17:40 UTC#154
downloaded the east disc, worked 100% on my D2
can't thank you enough!
Posted Oct 08, 2008 · 17:41 UTC#155
So the east disc thats on your server is the n5?
Posted Oct 08, 2008 · 18:40 UTC#156
I am starting to here onthis site about THE ACtUAL CNDV 80 EAST DISK ok what is the east disk down load that is on this site for download now and when is the actual 80 disk be on here for download???
Posted Oct 08, 2008 · 19:25 UTC#157
when will the real east disk be posted for the d 3 , not the one for the n 5?
Posted Oct 08, 2008 · 19:26 UTC#158
It works on my D3 is all that I know. I have heard that it is the actual disk and I have heard that it is not. I know the ones that will be up later today will be the actual disk. I have actual pictures of the disk which will update all of the N-Series and D-series. I am told the disk that are up there now will only update the D3, N4, and N5.
The actual Disk will update all of the N-series and D-series
Posted Oct 08, 2008 · 19:53 UTC#159
the actual discs are supposed to update the background did anyone notice that?
Posted Oct 08, 2008 · 20:40 UTC#160
nope not me, same back grounds
Posted Oct 08, 2008 · 20:43 UTC#161
Why doesn't someone make a torrent already. Give these guys a break. If I could get these damn things to un-rar without errors, even with WinRAR 3.80, I'd do it myself. :x
Posted Oct 08, 2008 · 22:13 UTC#162
My server is fine with handling the traffic. I was actually surprised that it handled it better then when it was on digg
Posted Oct 08, 2008 · 22:21 UTC#163
hmmm... I updated my D3 and my D1 using the east disk you posted. I DL'd it on the 4th.
How are you supposed to know what's what?
Posted Oct 08, 2008 · 22:33 UTC#164
If you were able to update your D3 then it was in fact the real CNDV-80MT disc. I know for a fact that the West coast disc was a disc from the N5. I will have the actual CNDV-80MT disk for download tonight. If you have a working disc there is no reason for you to download the new disc unless you want to. This is more for the people that have had the wrong disc for their unit and have not been able to update it
Posted Oct 08, 2008 · 22:36 UTC#165
so are there any new backgrounds on the actual 80 east disk?
Posted Oct 08, 2008 · 22:39 UTC#166
Have no clue I have my custom backgrounds set
Posted Oct 08, 2008 · 22:55 UTC#167
My 2 cents...
I have an N2 that was updated with 70MTP discs. I burned both 80MT discs, it reads the west disc but says incorrect disc (or whatever when it tries to update. However the east disc updated just fine. After that, it reads the west disc for navigation just fine. Just an FYI...
Posted Oct 08, 2008 · 23:07 UTC#168
THANK YOU SOOO SOOO much for this update...I ended up having to get a new burner(Pioneer 116d-$28 from newegg) in order to burn the disc correctly ...but the update went smooth as can be on my D2!!!!!
i followed this procedure from raiden
Unzip the file with latest version of winrar so you have an .iso
download and open imgburn
go into Tools -> Settings
Go to the Write Tab
At the top right, (Layer Break), click on User Specified
Enter 2084960
Click on OK to go back to the main screen.
Click Write image file to disc
Click on the icon next to "Please select a file..."
Select your .iso file
make sure write speed is maximum 2.4x
Click on the "file to disc" icon at the bottom left of the screen. (Under the Verify option)
There you go!
and i used verbatim dvd+r dl disks
For those of you who can't get it and would like a copy contact me and I'd be willing to do it for you!
Posted Oct 08, 2008 · 23:29 UTC#169
Under my software info on the nav... it actually states the cdnv80mt-something something.....I can't remember what it said.... there was no new backgrounds.... I didn't notice any changes really except for the Maps.
Posted Oct 08, 2008 · 23:48 UTC#170
oh ok
Posted Oct 09, 2008 · 00:09 UTC#171
I can make you a copy, i just got a 20pack from bestbuy od dual layer disc and i'm triyng to burn the disk.
Where a you located???
Posted Oct 09, 2008 · 00:15 UTC#172
Ok. I have downloaded the .zip version 3 times now. WinRAR 3.80 shows it as ~8.1G and begins to unpack it. Everything seems normal until it finishes at 100%. I get a small alert window saying the ISO is corrupt. Obviously other people are having no problems, so what could be my problem?
Posted Oct 09, 2008 · 00:17 UTC#173
that after you unzip it, i sould be 7.6 gigs
Posted Oct 09, 2008 · 00:21 UTC#174
Mine says 8,166,576,128bytes
Posted Oct 09, 2008 · 00:23 UTC#175
that is correct
Page 7 of 10
