For everyone that have F500BT, here is a soundtest program I need you guys to run since I dont have a F500BT to test. Extract the following zip file to any folder on the SD card, run CE TESTMODE and then execute it. The program should display 3 buttons, click on the buttons and tell me which button makes a beep. Next go into your "control panel" -> System -> Device Name (tab). Here you should see the Device Name please post what you see here. Please post your test result so I can change the launcher to work for the F500BT.
Thanks ![]()
