LeetLauncher v3.0!!!
By leetcoder · Oct 11, 2008in Completed Mods/Themes💬 844 posts👁️ 380,404 views
Page 12 of 34
Posted Jan 10, 2009 · 16:30 UTC#276
I am still trying to get Garmin to keep sat signal on, can't get it working. Any member outthere have any suggestions or solutions to this problem. That is about the only thing left to make the LeedLauncher perfect for me. The signal seems to work until I drive away for about 30-40 seconds.
did you copy that updated sys.txt file? if you didnt, then i would suggest you try that, from my understanding this will allow you to use the gps signal with igo, garmin or tomtom
be aware tho, that when i did this, i was NOT able to use the stock navigation
Posted Jan 13, 2009 · 13:36 UTC#277
Hello everyone, sorry that I haven't been around as much anymore.
In a day or two i'll try to update the 3 navi software to fix some issues people is having problem right now. I think I might know a fix for that garmin and i will post a solution when possible.
LeetLauncher software is still being delayed due to the fact that I am still trying to work with the pioneer library and it isn't that easy :(.
Posted Jan 13, 2009 · 15:13 UTC#278
It is good news! Thanks that have not stopped on the reached successes.
Posted Jan 13, 2009 · 22:40 UTC#279
Sweet - keep up the good work 8)
Posted Jan 20, 2009 · 23:25 UTC#280
Hi Leetcoder,
Awesome work! Congrats!
Could you also send me the file to fix the sound of the F500bt?
Additionally, do you have any idea of how could I fix the EQ into Jazz type?
When I use the ipod it doesn't let me choose the EQ type (i believe it relies only on the ipod EQ) and the sound is very poor without that.
Using the same music files into an SD gives me the EQ option making the sound way better.
Posted Jan 21, 2009 · 02:32 UTC#281
new here, i must say this launcher is one of the reasons i bought my f700, one question though, i was wondering if i could just use the launcher without all the other stuff, i only want to be able to go to testmode and the avic without having to reboot the unit, and also if it possible, lets say i used the launcher and went into testmode is there any way i could go run the avic without having to reboot the unit,
keep up the good work leet
Posted Jan 22, 2009 · 08:26 UTC#282
Updated iGo to 8.3.2 (with speedcam and kikker skin) and TomTom to 7.9.
Also for those that have F500BT, try out the fix and tell me if it work.
SEE POST 1.
Posted Jan 22, 2009 · 09:12 UTC#283
Also here is Dimka Specter Skin for the Igo 8.3.2
http://uploaded.to/?id=9olbfl
Posted Jan 24, 2009 · 19:16 UTC#284
Hi, writing from Germany. Can tell everybody, that OziExplorerCE runs perfect with the leetlauncher on my F900. Great work, congratulation, hope you will continue.
Posted Jan 25, 2009 · 09:20 UTC#285
hey leetloader,
thanks for this!!!! just a quick question... so i load igo first, then once everything is loaded and working, i hit the MENU button and then down... then i press on the pioneer logo and once everything loads i see the Destination/Contacts/and the last option i forget what the name was, lol.... When I hit phone on the main menu, a pop up comes up saying it has done something illegal of some sort.... does bluetooth work when using your launcher?
any help is greatly appreciated...
and again, thanks for this very nice launcher
Posted Jan 25, 2009 · 11:49 UTC#286
SEE POST 1.
Hello Leetcoder,
I tested LeetLauncher 2.0.5 with iGo 8.3 on my European F500BT and it works perfect with sound. Great job!
Is it possible to run iGO 8.3 (autorun) without the Leetlauncher menu and without the possibility to return to the LeetLauncher menu (button down disabled)? I would like to use my F500BT as a stand-alone iGO 8.3 or TomTom navigation unit just by inserting the appropriate 2 GB SD card with eiter iGO 8.3 or TomTom on it. I don't care for the other options such as testmode or the audio function of the F500BT.
I noticed that iGO 8.3 and the original Pioneer navigation software share the same settings. If I change settings like color schemes in iGO 8.3 it changes the color schemes for Pioneer as well. Is it possible to have different settings for both?
Thank you for your efforts. I realy appreciate it.
Posted Jan 25, 2009 · 12:55 UTC#287
Hi Leet, great job with the launcher, thank you for your work.
When I launch igo8, I cant have blue tooth running, when I go to the pioneer menu, and click on the phone button, I get an error. Is it possible to have my phone connect via bluetooth while running igo8?
any help is appreciated, thanks
Posted Jan 25, 2009 · 15:43 UTC#288
^^^ Having same issues as well....
Also, I have all the files to get TomTom going, but still can't get the map to activate... Can someone please help me out with this?
Thanks in advance.
Posted Jan 25, 2009 · 16:45 UTC#289
My Tom Tom works great. Its Igo that I have a problem with. Its looking for a graphic called loading.bmp and then exits the program.
Does anyone know where this is or where it goes?
Posted Jan 25, 2009 · 17:53 UTC#290
hey bwolfe, maybe try to redownload the launcher??? and just overwrite the igo folder???
how did you activate your tomtom??? when i try to run cmd it tells me the command is not know command
Posted Jan 25, 2009 · 21:41 UTC#291
Great having Igo 8.3 on the device :) Thank u.
As far as i remember, bluetooth never worked yet with leetcode mod. So it's normal to have a crash when trying it out.
Leet, can we hope to not have to "launch Igo, then MENU, then DOWN then PIONEER", everytime we start the car ? Can't it be done automatically so that we have the avic with Igo ready without pressing any button each time we start up the car ? This shouldn't be too difficult, isn't it ???
Thanks a lot,
Posted Jan 26, 2009 · 00:42 UTC#292
Finally got the maps and everything is working... Both iGo8 and TomTom...
Posted Jan 26, 2009 · 01:05 UTC#293
I have searched, but I may have already overlooked it, but, how do I get the Sirius radio, sound and all Pioneer options when running the Beta Igo 8.32 and Leetlauncher? When I use IGO, all I have is just the maps and I can't listen to my Sirius or change any settings or use Bluetooth or any other Pioneer options for that matter.
Also, the guidance volume is LOUD and changing the volume controls to minimum does nothing until I turn them completely OFF.
Thanks in advance.
Posted Jan 26, 2009 · 01:14 UTC#294
Thanks in advance.
I'm having the same issues with the sound! I was able to use fm stations with the igo 8.3.2 but nothing else. Leet has told us that bluetooth is not compatible with igo yet, but is with tomtom i beleive.
Posted Jan 26, 2009 · 20:54 UTC#295
Leet, you're a genius man! Hope you get the Garmin to stop dropping the GPS after a couple of minutes. The only maps I can get for my area are Garmin maps, so if you get the bugs out of the Garmin XT for the launcher I'll be eternally grateful. Keep up the work dude! :lol:
P.S. Anybody knows what happens if you copy the launcher files to the system disk?
Posted Jan 26, 2009 · 22:50 UTC#296
Hey Leet Awesome work really what you have done is nothing short of amazing! Just wanted to give you props!
I have a question tho... I read every on the post on the leetloader and no one has made a comment about this. Does the leetloader work with MSNDirect and re-route traffic automatically the way it does with AVIC? This is extremely important to me because I live in LA and traffic is out of control.
Thanks in advance and again awesome work!!!
Posted Jan 27, 2009 · 14:38 UTC#297
There is an other way to express your gratitude -)
Thanks, Skippy2
:D
Donation:
Keep me Motivated :lol:
DONATION
Posted Jan 27, 2009 · 14:52 UTC#298
Yeah, but when he's putting all the funds to a 2nd avic for testing, to help all of us out, it's probably the best way :wink:
Posted Jan 29, 2009 · 00:25 UTC#299
I just got my F500BT 2 days back and was super dissappointed with the mapping software(old maps, too many key presses to get to "route list", no easy access to gps signal quality, no ability to set heading up instaed of north up)
Leetlauncher later, I now have IGo 8 working fine and am very pleased with my purchase.
Posted Jan 29, 2009 · 07:07 UTC#300
Hi , can anyone tell me if i can backdate the version of igo8.32 so that the australian maps work . As i get an error saying that maps are out dated and there are no newer maps availabe for australia
if so what version would recomend and how to
thanx
diggs
Page 12 of 34
