LeetLauncher v3.0!!!
By leetcoder · Oct 11, 2008in Completed Mods/Themes💬 844 posts👁️ 380,404 views
Page 14 of 34
Posted Feb 13, 2009 · 03:50 UTC#326
so any updates?
Posted Feb 13, 2009 · 18:12 UTC#327
Just tried the launcher, on a freshly formatted SD.
Booted, everything well, selected IGO, fine, chosen my language, and then it showed the IGO bootscreen with an error: no maps available.
I hit OK and waited... and waited and waited... 19 minutes
nothing :cry:
Refuses it to boot without any map data? or should it run anyhow?
Posted Feb 13, 2009 · 19:10 UTC#328
You need at least a basemap...
Posted Feb 13, 2009 · 19:39 UTC#329
I stand corrected: that does work with maps loaded
Posted Feb 14, 2009 · 06:26 UTC#330
is this no longer a sticky?
Posted Feb 14, 2009 · 20:43 UTC#331
hey leet,
after running iGO from your launcher i noticed a couple of things, the bluetooth won connect, and whenever i'm on the av screen, when i click the map button on the lower right of that page it shows the old map not the 8.3.2 version
Posted Feb 15, 2009 · 16:28 UTC#332
hello.... how do i load new backgrounds into a 700bt?? any help would be great thnx
Posted Feb 16, 2009 · 21:58 UTC#333
Hi
Any body living within the Los Angeles area?? I really need help. I read through all 23 pages, downloaded and followed the instruction, but couldnt get the Igo8 to run on my 500bt. After boot up the new launcher screen, pressing Menu will do nothing on my device. Pressing down.. the screen flcikering, but nothing change. I believe I did something wrong with the file structure. Already redownload and tried different things, couldnt figure out. If any of you living around the los angeles or Orange county aread, please help me, maybe have a look at my Sd card... all I wanted is to have to Igo8 to run on the 500bt. Thank you
Posted Feb 16, 2009 · 22:34 UTC#334
Hi
Dumb question.... If you want to run igo and you live in the US, why do you need to run the launcher?!?!?
Anyway after the launcher menu appears you need to click in what option do you want to run, after that you need to do the menu/key down to chsnge between apps...
GUGA
Posted Feb 16, 2009 · 23:57 UTC#335
GUGA
Thanks for a quick respond. Im new to this.... The reason I run launcher because I want to use the new IGO 9.3.2, nicer GUI, new map.
I already tried pressing all the button, different sequences... no respond whatsover, except pressing down the screen flickering, but nothing happened.
Posted Feb 17, 2009 · 01:51 UTC#336
I read through the whole forum today. There are so many cool hack for this unit. Too bad I dont know enough of the software to make it run... Can some one please help me on this?? Thank you so much
Posted Feb 17, 2009 · 02:27 UTC#337
is there really a 9.x.x version?
Posted Feb 17, 2009 · 02:29 UTC#338
he ment 8.3.2 igo
Posted Feb 17, 2009 · 15:35 UTC#339
I there, people!
I'm a newbie here and I'm getting my US version of the F700BT tomorrow! I'll be installing it in the weekend! :D
Please answer me the following question:
• we need to have the SD card with these files every time we turn on the ignition?
Posted Feb 17, 2009 · 15:52 UTC#340
I there, people!
No I just did my first "hack" added mute to nav menu - once you overwrite the data on the flash drive built into the unit its done... at least in a F90BT
Posted Feb 17, 2009 · 23:31 UTC#341
Sorry for the dumb question, but what are the .dem files for? Do I really need them?
Posted Feb 18, 2009 · 01:32 UTC#342
They are for displaying elevation/landscape on the map instead of a flat street grid. They are not really necessary, just make the map screen look more injteresting...
Posted Feb 18, 2009 · 03:54 UTC#343
Newb here, but how do you launch the leetlauncher on the F500 when I have it extracted onto my sd card. Does it auto load on startup or do i have to click on something in windows ce?
Posted Feb 18, 2009 · 04:07 UTC#344
read a couple pages back and you'll find your answer
Posted Feb 18, 2009 · 04:14 UTC#345
I can only find iGo 8.3.1 maps for the US. Will these work with the iGo software included in this launcher, or must I find 8.3.2 maps? If the latter is the case, can anyone help point me in the right direction?
Posted Feb 18, 2009 · 10:30 UTC#346
And to where exactly do I copy those .dem files? Inside the maps folder?
Thanks for your answers!
Posted Feb 18, 2009 · 11:09 UTC#347
Normally in the DEM folder.
Let me know when you found a working dem file for EUROPE.
I have two (Eorpe TA and EUrope NASA) and they don;t seem to make ANY difference.
I've checked with area's like the alps, but I don't see any mountainroads or so on a slope, hill or mountain displayed.
Posted Feb 18, 2009 · 14:27 UTC#348
8.3 maps should be fine. Incompatibility is between 8.0 vs. 8.3 formats.
Posted Feb 20, 2009 · 03:25 UTC#349
not sure how to get product code or device number to get the maps activated... any ideal? thanks
Posted Feb 21, 2009 · 07:08 UTC#350
any updates?
Page 14 of 34
